Old 12-24-2019, 05:04 PM #1
Dirtrider216 Dirtrider216 is offline
Dirtrider216 will become famous soon enough
Hi lift tube mount on stock roof side rails
I’ve been trying to get a good secure mounting solution for my 60” hi lift jack on my stock roof rack.
I came across this
Adjustable Tube Mount | Hi-Lift Jack Co.
And I was wondering if anyone has any experience with it and whether it would work on the stock 4Runner roof rack side rails(not the cross bar but the actual sides ) and would the sides be strong enough to hold that securely?
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
Dirtrider216 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 07:04 PM #2
montijo505's Avatar
montijo505's Avatar
I see no real reason why it wouldn’t work. Report back with your results!
Old 12-28-2019, 12:29 PM #3
So for those who want to mount a high lift securely and easily to a stock roof rack these small size hi lift tube mounts work perfectly! I mounted mine angled slightly outside, you could go inside if you remove the oem cross bars. I also got the handle keeper but there’s still considerable rattle with it so I just threw a zip tie in as well and that eliminated the rattle as far as I can tell!
I will be ordering a lock for the hi lift mount now that I know they fit without a problem
2006 limited v8 4wd
Old 12-28-2019, 12:48 PM #4
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
So how hard is it to hoist that sucker up and down off the rack? I considered this as an option, but my hi-lift brand jack is an older heavier model and I just have visions of A) eating shit trying to get it up there after use on snowy terrain when I needed it last, or B) slipping on the same snowy terrain and wiping out a door panel or a window. Thoughts?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 12:51 PM #5
I have it positioned so that I can stand inside the rear door and put a foot on my tire if I have to but essentially I use the front as a pivot and take the heavy back off first and then when the back is clear of doors and windows I take off the front and let it in a controlled slide to the ground
Edit: I spend a fair amount of time in the gym so with my 60” Jack it’s a one arm deal to lift it up and down vertically and my second hand only controls it from swinging when I pivot it
2006 limited v8 4wd
Old 04-02-2020, 10:02 PM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
@Dirtrider216 Just found your thread here. You confirmed what I had pictured in my head for fitment on our racks. Thank You!! I have a set of these arriving tomorrow, did you find a suitable locking device?
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 10:52 PM #7
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Thank you for this thread
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 09:31 AM #8
I just threw a cable bike lock around the roof rack and jack as a theft deterrent. Since the car is lifted and I dont have running boards you would have to either be very tall or very strong or put yourself in a suspicious looking situation to try to take the jack. I have to stand inside the rear door with 1 foot on the back tire to take it off, so trying to do it from outside the vehicle would not be easy or pleasant.
2006 limited v8 4wd
Old 04-03-2020, 01:01 PM #9
Real Name: Brett
Real Name: Brett
5 minute install, built pretty solid.
Hi lift tube mount on stock roof side rails-4th-gen-hi-lift-mounts-jpg
Old 04-03-2020, 01:55 PM #10
If you notice any heavy rattling, one of the climbing pins on the hook portion of the jack is probably extended down and touching your roof rack, cycling the handle should move that. I also had light rattling that i solved by throwing a tarp strap i think either 8" or 11" around the rack, and the moving portion of the jack and that essentially cleared up all my noise
2006 limited v8 4wd
lift , rack , roof , sides , stock
06 Tube Roof Rails on 04 Chronus 4th Gen T4Rs 1 03-06-2019 11:41 AM
2014 Trail Side Rails and Stock Roof Rack RedStripeRanger For Sale: T4R Items 4 09-03-2015 03:03 PM
Side firing LED's that fit under the stock roof rack rails swapmeet 4th Gen T4Rs 9 07-14-2015 09:46 PM
