12-25-2019, 11:29 AM
Unlatch new tailgate latch
So I replaced the tailgate on my 07 sr5. The latch came closed and I have the door installed and everything works but I cant get the latch open to close it. Any thoughts?
12-25-2019, 12:00 PM
There are 2 levers on the lock mechanism that I believe locks or releases. Can't remember off hand which lever and what direction but I'm sure you can find via Google. You may be able to access by removing a little plastic cover on inside back panel or may need to remove the whole panel. Had to do when replaced my lock a few years ago.
12-25-2019, 01:36 PM
Real Name: Elliott
Real Name: Elliott
You need to reset the door. Everything was unplugged when you changed the door. Try locking and unlocking with the fob a couple of times. I bet the window won't roll down either, same reason.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-25-2019, 01:40 PM
Thanks! Turns out. My dad diubd the hit pin on the harness and jumped it to the battery. Opened right up.
12-25-2019, 01:55 PM
Real Name: Elliott
Real Name: Elliott
Only real problem I have with that hatch: it requires voltage to work. Good thing I have 2 batteries. Merry Christmas.
