Old 12-25-2019, 04:59 PM #1
Morphyne Morphyne is offline
Morphyne is on a distinguished road
Power locks died
So I replaced my liftgate yesterday. My father started cutting the wires before I unconnected the battery. It sparked. We got the new gate was installed and everything works except my key fobs and I have no constant power to the locks. Meaning my locks only work when the key is on.
Any thoughts?
Morphyne is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 05:36 PM #2
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
Check.fuses
Sent from my SM-G950U using Tapatalk
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 06:12 PM #3
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner will become famous soon enough 81runner will become famous soon enough
81runner's Avatar
Real Name: Elliott
When you disconnect the battery, everything needs to be reset. Power locks, windows, sun visor. Close all doors. Lock with the fob a couple times. Then try it again
2007 SR5 V6 4WD, Titanium Metallic. 5100s, OME 885/895, extended rear links, Cooper ST Maxx 255/75 R17 on 17x8s, mud flap delete, throttle body spacer, Cold Air Intake, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, COB LED drop-in lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, Rigid Armor tire carrier, SE hood w/functional vent, Pedal Commander, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v hookup, dash mounted tablet, rear diff breather, pck, Freedom UCAs, custom stereo....for now....
81runner is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 08:44 PM #4
Fob is dead. I get no response from fob and nothing from locks unless the acid on. Super weird. It seems like the loop for the constant power to the power locks has been broken. I'm liking the anti theft module being bad after the tail gate transplant.
Old 12-26-2019, 08:22 PM #5
weaves weaves is offline
weaves is on a distinguished road
The body control module, which controls the locks, should have a constant 12V to it with the ignition off. It gets the constant 12v power from the 10A "ECU-B" fuse in the engine bay. My guess is that you blew the fuse when you shorted the wires while removing the tailgate.
weaves is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 01:14 PM #6
I checked that fuse and it looks good. Any other ideas?
Old 12-30-2019, 11:00 PM #7
There's a 20A fuse for the power door locks but it's unlikely your issue since they work with the ignition key ON. Is everything else working like your dome lights and door ajar indicator light (instrument cluster) with the ignition off?
Old 12-31-2019, 09:59 AM #8
No. I have no power without the key. No dome lights, nothing.
Old 12-31-2019, 02:09 PM #9
Either the constant 12v signal to the body control module is broken which would be due to a blown ECU-B fuse or faulty wiring or you could potentially have a bad BCM, both which are highly likely given your circumstances. I would first check to make sure you're getting 12v to the BCM with the ignition off.
If you pull the cover for the interior fuse box/distribution block/BCM there will be a white 13 pin connector (smaller of the two) on lower right. Remove the connector and check for 12v on Pin #4 (white wire w/red stripe) with the ignition off. If there's no power there then you have a broken link between the ECU-B fuse to the distribution block/BCM.
key , locks , meaning , power , work
Power windows / power door locks inop jimlaw3 Classic T4Rs 3 12-24-2015 04:00 PM
inconsistent power to power locks 99 4runner Sierra Runner 3rd gen T4Rs 1 05-20-2012 02:59 AM
Rear power window/ Power locks Brian Keeler 3rd gen T4Rs 2 06-01-2010 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
Power Brake Booster died and they want $850? Should I do it? stealthauto Classic T4Rs 4 11-09-2008 12:55 AM
