Old 12-26-2019, 09:07 PM #1
JackDuggan JackDuggan is offline
JackDuggan is on a distinguished road
Oil cooler types
I am planning to put an engine oil cooler on my 2008 V6 T4R but I can't decide between the Toyota type, using engine coolant, or the air type cooler. Looking for some opinions. I use the vehicle to tow my Six Metre Argosy Minuet trailer, which weighs 2500 dry, 3500 max.
I had good results on a previous tow vehicle with the finned Hayden type, but I also have the coolant type on my Focus SVT and I know that's the type we put on Mustang 5.0's back in 1990 when I sold them in Germany.
2008 V6 RWD SR5
JackDuggan is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 10:30 PM #2
ElDuck ElDuck is offline
ElDuck is on a distinguished road
Smile
Could you show me an example of the Toyota coolant type you're referring to?
ElDuck is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 12:14 PM #3
have you verified your oil temps to know you actually need an external oil cooler? never heard of the v6 having an oil temp issue, especially towing only ~half of its rated tow weight. if you run a good synthetic oil, i dont see towing that much weight causing an oil overheating issue.
i'd be more concerned with the trans fluid temps since the v6's dont have an external trans cooler, but again toyota felt that the v6 system was ok up to 5000lbs.
granted, if i towed frequently i would want an aux trans cooler, but i dont think you need an oil cooler unless you verified you have an overheated oil issue.
Old 12-27-2019, 02:51 PM #4
I guess I should have included in the original post that I installed an auxiliary transmission cooler and can monitor the temp through OBD.
I'm looking at doing a Tee fitting so I can install an oil pressure and temp gauge. An advantage of the air type cooler is that the sandwich adapter has ports for these gauges.
2008 V6 RWD SR5
Old 12-30-2019, 12:31 PM #5
Here's a link to a video of an installation. This type of oil cooler was installed on the 1GR-FE V6 in the Tacoma with tow package I think.
YouTube
2008 V6 RWD SR5
coolant , cooler , oil , type , vehicle
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
TRD CAI 2 types? John619 4th Gen T4Rs 1 04-18-2010 12:24 AM
Is that a trans cooler or oil cooler in front of the AC Condensor? kn38ms 4th Gen T4Rs 8 06-05-2008 07:41 PM
Oil Types 4RUNR88 3rd gen T4Rs 11 01-11-2007 10:14 AM
