Old 12-27-2019, 03:09 PM #1
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Need another gas cap after 27 months, has anyone disabled the evap testing system?
Just like last time, C1201 - P0441 - P0455 codes returned. I suspected they may, because the gas cap has felt loose for the last couple of months. OEM Toyota gas cap.
As I understand it, the evap system is pressure tested when the 4R sits idle for at least five hours, and then a pressure pump or a vacuum pump is activated for a system test.
I'm wondering if anyone here knows where the pump is located, and what would happen if I disable the pump by disconnecting its electrical supply?
Would my 4R go on with life with an imperfect gas cap, or would I get the mother of all CELs?
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 03:18 PM #2
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
hope its your gas cap and i know that does often resolve evap codes.
sorry to hear about this though, i had a 'small evap leak' code on my wrx and without doing a smoke test and even when doing them the evap leaks can be pesky i heard... so much so that i actually sold the car with the evap code as is, to a 15 year old potential or future gangster (technically sold to his 32 year old smokeshow madre). kid got a 2005 wrx, stock car with 90,000 miles for 5 grand. i didnt even try the gas cap i was so over that fn car. got it with 38k miles and in less than a year timing belt broke while driving (seized water pump) and i had to cut a $3 grand check for all new valves.
to your ending question, i was told that a small evap leak is also pesky in a sense it could be 500 things and also more than likely run perfectly fine.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 01:31 PM #3
tehrunner tehrunner is offline
tehrunner is on a distinguished road
Do you “top off”, when fueling up?
tehrunner is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 03:07 PM #4
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
That's a good one, so many people don't know that they trashing charcoal canister by overfilling gas.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 06:15 PM #5
Yeah, and that causes lots of evap issues. Don’t top off!
Old 12-29-2019, 09:20 PM #6
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
OEM gas cap is $12 on Amazon. Buy a new one.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 02:02 AM #7
little_titan little_titan is offline
little_titan is on a distinguished road
In less than 2 years i went through 2 non oem gas caps and 1 toyota gas cap...now im fed up and going to try just replacing the rubber gaskets on the toyota gas caps.
Not sure if it has to do with the cold Chicago climate and the gas cap gaskets drying up?
But this never happened to me while i was in Dallas for 2 years.
2008 w/ 147k
little_titan is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 02:22 AM #8
No, I don't top off.
Where did you find the gasket in the cap? I looked and didn't see anything like a rubber o-ring. I did see a sealing surface that appears to be a flat plastic material.
Old 12-30-2019, 07:20 AM #9
Burt Burt is offline
Burt is on a distinguished road
Just buy a new gas cap. I had to a few years ago and bought a Stant replacement cap. You'll never pass smog test if you modify/disable any of the emission systems.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 08:16 AM #10
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I just looked at my gas cap and it does indeed have an O-ring on the plastic center section just past the threaded portion fitted into a groove, It appears to be the original cap but not sure if it is, I have never replaced it and it looks old.
2004 Limited V8
Old 12-30-2019, 11:03 AM #11
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Sometimes a light coating of grease on the o-ring will help it seal better.
That will also help diagnose the leak, if the cap is sealed then you know to look elsewhere. There was a thread here about failed hoses and connectors over the gas tank. They had rotted away.
I use the same silicone grease that I use on the brake pad pins.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
cap , gas , months , pump , system
Charcoal Canister / EVAP System Delete? Clayton74 3rd gen T4Rs 35 02-13-2024 04:43 PM
Code P0456 and System Testing Utah_4runner 4th Gen T4Rs 11 12-18-2019 03:51 PM
Security System Disabled? knecoli22 4th Gen T4Rs 4 03-22-2019 11:52 AM
Evap system incomplete Msg ! Mellemel 3rd gen T4Rs 2 01-18-2016 07:38 AM
EVAP System Removal Cartmendez Classic T4Rs 0 06-08-2011 08:33 PM
