Originally Posted by azgold
My 2006 4.0 T4R with 215K finally threw a check engine light.
P0430 Cat System, Bank 2
I`ve read conflicting statements ....Is bank 2 the drivers side or Passenger ?
Can I really check the Inlet & outlet temps on the Cat (Manifold) and know if the cat is the issue?
Any thoughts would be appreciated...
Any ideas as to what I should do next?
I think it's just about time to replace your Cat on both sides including the af sensor and be done with it. Sooner or later the other side will fail too when you least expect it.
Others will suggest to do other things to save you money but if you think you will keep the truck as long as you can, it's worth spending the money.
