Old 12-28-2019, 04:26 PM #1
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Multiple random misfires,p0300, p0302, p0303
So am helping a pal diagnose an issue on his 07 runner.
P0300,p0302, p0303 all persistent and refuse to go away.
Swapped coils, changed plugs, swapped injectors, Cel refuses to go away.
Plugs removed were brownish in color.
We are really stumped.
Any clues on what could be the culprit?
Fuel trims are 11% and 19%...car idles ok..but Cel triggers on giving it gas
Could a bad fuel pump be responsible??
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 08:54 PM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
0302 refers to cylinder 2, 0303 refers to cylinder 3. I'm thinking it could be fuel pressure related. Maybe the pump, maybe the pressure regulator. Have you tested incoming fuel pressure yet?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 05:03 AM #3
Nope he hasnt tested the fuel pressure yet, however he changed the fuel pump about 8 months ago, on the advice of his mechanic.
My question is why the bank 2 and 3 are being highlighted...i thought fuel pressure related issues would affect the whole cylinders
Old 12-29-2019, 12:04 PM #4
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Could be an issue with a specific injector, or an issue with the routing of the fuel rail. Could also be related to the plug or coil on that cylinder (not bank). The code simply refers to a misfire on a particular cylinder.
Old 12-29-2019, 02:51 PM #5
We swapped injectors, coils and replaced plugs.
No change same codes p0302 , p0303, p0300...
Filled tank with gas.just incase he had contaminated gas...no change either,
So either the fuel pump or leaking head gasket are my suspects now
Old 12-29-2019, 03:02 PM #6
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
After everything that you have done, i would check fuel pressure with truck running and off. Don't know the specs but basically pressure must be stable with key off, not dropping. Check pressure at the moment of misfire if it drops. Try swapping
Fuel pump relay also for a known working one. Clean mass air flow sensor, if all good then compression test and leak down test.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 11:19 PM #7
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Agreed. Pressure is 42psi minimum, I believe. If it drops below that, you'll misfire. If you have an issue with a leak in pressure, it'll misfire. Could be the pressure regulator or the pump itself. Could also be a plug is not gapped right tbh. Misfire is occuring due to a loss in fuel, air or spark, and your codes refer to specific cylinders. Could be an issue with the coil plug having a bad pin or a boot with a hole in it shorting to ground. Pressure should be consistent across all cylinders, so I find it odd that delivery of fuel would be the issue. Could also be an issue with cylinder compression from a bad ring or a stuck valve. Or if the tank was low on fuel, you could've sucked particulate from the bottom of the tank and it's fouling your new injectors. Not always so cut and dry. The pump could have crap in it that's gotten thru the filter sock and it's floating around and sometimes clogs the pump, the pump could just be getting tired or it's getting hot after a few minutes of running because it's worn out. Start with a baseline, what's the fuel pressure?
Old 01-12-2020, 04:15 PM #8
owner was unable to test the pressure, swapped the fuel pump with a new unit, issue persisted and got worse... observed coolant level was reducing in reservoir tank. all of which pointed to a HG failure,owner took the vehicle to repair center, all 3 plugs on passenger side, soaked in oil.
HG failure confirmed, 07 v6 bought used at 206k miles, now 215k miles... any other part to replace while doing the head gasket job
Old 01-18-2020, 03:04 PM #9
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
If the plugs were soaked in oil, then the spark plug tube gaskets are leaking and should be replaced. Common issue. You should start with replacing all 6 tube gaskets before doing the HG and go from their.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 11:40 PM #10
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Agreed. The tube gaskets are under the valve covers. Replace the valve cover gaskets and tube gaskets. Head gasket would leave oil in the coolant. If the level is dropping, could be from pump pressure and he's running low. What color is the exhaust? Water in the tail pipe usually results in white exhaust. If the issue is related to a head gasket that would be a good sign. If it is blown, my guess is it was getting hot
Old 01-19-2020, 01:06 AM #11
So what would have caused the tube gaskets to go bad?.
The oil was worse on bank 1.
Could the shorter plugs be the culprit?.
2ndly, attached is pic from the bank 1 cylinder.wonder what would have made the mark there.
Car was stopping intermittently and unable to move meaningfully.
Owner has instructed mechanic to commence the repairs
Multiple random misfires,p0300, p0302, p0303-img-20200115-wa0010__01__01-jpg
Old 01-19-2020, 01:31 AM #12
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Did the mechanic clean that cylinder portion of the head or is that the way it looked when they pulled the head?
2004 Limited V8
Old 01-19-2020, 05:15 AM #13
Blueish smoke from exhaust at start up.
Didnt see oil in coolant.
Removed the radiator cover , started the car and checked for gas bubbles.....none either.
He didnt have coolant in the reservoir tank initially, got him to fill up to full mark and it gradually reduced by about an inch per week. Intercity driving, say about 100 miles weekly
Old 01-19-2020, 05:18 AM #14
Thats the way the cylinder was.scuffed/pitted.
Recall he had persistent p0300, p0303 and p0302.
Which failed to go away when we swapped plugs, coils, injectors
Old 01-19-2020, 11:28 AM #15
Real Name: Skip
Real Name: Skip
Blue smoke at startup is from deteriorated valve seals, oil leaks passed the valves seals when the engine is not running and then burns at startup.
Not sure what could cause the pitting but the clean metal is most likely from when the coolant was turned to steam when the cylinder fired.
2004 Limited V8
cel , fuel , p0303 , plugs , swapped
Flashing CEL with P0300 and P0303 Rock_Rat 3rd gen T4Rs 21 05-26-2022 02:48 PM
P0300, P0302, etc. sdb999 3rd gen T4Rs 4 03-06-2016 08:07 PM
p0303 to p0300 jinxed13 3rd gen T4Rs 4 06-10-2013 09:48 AM
Help! P0300, p0301, p0302 Chandler_Ross 3rd gen T4Rs 2 06-04-2013 11:22 PM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
