Old 12-30-2019, 07:26 AM #1
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
URGENT: ignition locked 300 miles from home
I just drove my V8 4runner 4x4, parked it, then came back to the car unable to get the ignition to unlock.
I have tried jiggling the key, and the key fob works on the doors. It is currently 3am. I will update the thread tomorrow after I figure out if the key unlocks the doors from a locked position. The key fob locks and unlocks the car.
I called a mobile locksmith and he stated the Toyota keyed iginitons fail and we would have to drill out the igition, turn it on then replace the igintion with a new unit. All costing upwards of 600 total.
Here are pictures of the key. I believe the key has finally worn out to where it will not engage the pins in the ignition.
I really want to get home, any info on this issue is much appreciated.
royal T4R is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 07:26 AM #2
I have tried jiggling the steering wheel and turning the key at the same time to no avail.
Old 12-30-2019, 08:09 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Try moving the key inwards and outwards just a tiny bit, the key maybe going to far into the ignition or not enough.
Good Luck!
2004 Limited V8
Old 12-30-2019, 09:05 AM #4
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
I've had this issue a couple times in the last 15 years. All I did was just wiggle/jiggle/push in/out. Sorry its not much help, but it is frustrating because last time that happened I was going in to work and already running late.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:10 AM #5
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
Sounds like a worn key. A friend of mine has an '03, he is able to completely remove the key from the ignition after he starts the vehicle. Might try heating the key and/or the ignition with a hair dryer to maximize tolerances. Crappy time of year to be stranded. Hope you get home soon.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 10:33 AM #6
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Y3ah its a worn key. My primary key behaves so, i can remove the key on ACC, thus having full radio functionality.
I have a spare key though, and several dumb ones, so i should still be able to start the car, if this happens to me
@ OP, try heating the key , it should expand a lil and maybe engage
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 01:28 PM #7
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Try a second key ? Maybe have one cut off a blank (cheaper) camry/corrolla . you need only to turn ignition while holding old key next to cylinder.
Drill it yourself..use old key and needle nose to get you home.
SaulG is offline   Reply With QuoteReply With Quote
car , doors , ignition , key , unlocks
Urgent help needed: Ignition Coil Bolt Sheared j_h_cole 4th Gen T4Rs 9 08-13-2018 07:55 PM
Key Stuck in Ignition!! need urgent help Tucson4runner Problems & Warranty Issues 19 07-31-2017 09:00 PM
Steering/ignition locked. thuan2k Problems & Warranty Issues 13 03-21-2016 11:24 PM
Ignition Locked? Please help! motion732 4th Gen T4Rs 8 03-04-2009 01:18 PM
Ignition locked, dont know why please help! ZachB Classic T4Rs 2 07-07-2008 11:21 PM
