Old 08-14-2020, 10:32 AM #16
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
The pistons are not chrome plated. That would be prohibitively expensive. Those talking about cerakote, that would not add any corrosion or abrasion resistance.
The titanium nitride (or copper nitride for that matter) usually needs to be plated on a material that will accept it such at nitralloy 135 (that material is used on fighter jets). You cannot machine nitralloy or nitride coatings easily so you would have to pay a grinding shop to hit the final OD of the piston ($$$).
So at the end of the day you're better off buying a new set of OEM calipers and change your brake fluid every year if you're worried about corrosion,
You can also pull off the dust boots on each piston and regrease them periodically. You're trying to reinvent the wheel where it's not necessarily warranted.
-aerospace engineer
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 01:21 PM #17
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Has anyone noticed a lesser amount of seizing based on which fluid they use?
I'm about to change my rotors and pads out and I'm going to full fluid flush as well. I used to use ATE Super Blue back in my racing days which now seems to be the ATE Type 200 Amber fluid now, thinking about that as it has good water binding properties.
Anyone use the stuff in our 4th gens?
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 07:25 PM #18
lbhsbz lbhsbz is offline
lbhsbz is on a distinguished road
The OE pistons are not just polished steel, they are chrome plated. They have excellent corrosion resistance. The issue is that moisture collects around where the boot fits to the casting...then slowly creeps under the boot and around into the bore where as the paint or zinc plating degrades, pinching the piston...as seen in your picture.
The problem becomes worse in rebuilt caliper because the surface where the boot fits is no longer a clean machined surface, but a blasted more porous surface...so the boot doesn't seal as well as it once did.
Once the caliper is all cleaned up and re-assembled, pull the boot back and squirt it full of silicone dielectric grease...then burp the air out until grease oozes out of it. Once it's full of grease, it won't get able to get full of anything else and it will live considerably longer.
This is not a toyota specific problem.
lbhsbz is offline   Reply With QuoteReply With Quote
brake , dlc , pistons , reasonable , tin
Coated Brake Claipers Ruthven13 4th Gen T4Rs 14 06-14-2018 11:30 AM
Powdercoat Brake Pistons or Bores? ZiaMan General Discussions 3 12-09-2017 03:37 PM
Frozen Brake Caliper Pistons? zerowkul98 5th gen T4Rs 0 10-24-2017 09:40 AM
Quick question about stuck 2 of 4 pistons in brake caliper. kacper 4th Gen T4Rs 12 04-13-2015 10:19 PM
Front brake inboard pistons 4RunnerConvert 4th Gen T4Rs 4 08-01-2011 08:24 PM
