Old 12-30-2019, 03:50 PM #1
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Coated Brake Pistons
Since basically everybody has issues with seizing brake calipers, the engineer in me came up with an interesting idea. Why not coat the caliper pistons, which are just polished steel, with something a little more durable such as TiN (Titanium Nitride/Gold) or DLC (Diamond Like Coating/Black).
The OEM pistons themselves are $15 each, so the front is $120, plus the seal rebuild kit $20
Total of ~$150 plus the coating cost
I have no idea what the coatings will cost but if its reasonable I think it would be worth giving it a shot for a group buy. I am trying to get quotes for TiN and DLC. If its reasonable we might be starting a list boys!!!
It's either that or try and get some machined from stainless steel.
Any other ideas? Who's interested?
Coated Brake Pistons-capture-jpg  Coated Brake Pistons-capture2-jpg
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 04:28 PM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
1 - will the coating survive brake fluid?
2 - how will you account for the change in piston to caliper clearance with a coating?
08TxRunner is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 04:56 PM #3
doofenshmirtz doofenshmirtz is offline
doofenshmirtz has a spectacular aura about doofenshmirtz has a spectacular aura about
I've got a guy I do some work for that has a CNC shop that mills maintenance/replacement parts for manufacturing equipment. Their tolerances are +/-.003" against whatever specs are provided. They mill stainless and tooling steel regularly, so this would be well within their capabilities.
Shops like this aren't particularly uncommon across the US, but if I can be of help, just tag me. I could theoretically buy a piston and model it in Solidworks to get a quote. If the coatings were to add an appreciable thickness, you could custom mill pistons to account for that.
As it stands, I don't yet have any skin in the game, because I've got lifetime warranty on my calipers, but it's fun to help out when I can.
doofenshmirtz is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 08:53 PM #4
Inv4drZm's Avatar
Inv4drZm's Avatar
As long as the orings aren't leaking you shouldn't need to worry about brake fluid compatibility.
DLC coating is .00025 inches thick. Even if the metal surfaces were used to seal instead of the oring the coating wouldn't interfere with anything.
I've got a couple shops here I'm more or less friends with, and have calipers and modeling software as well but thanks for the offer.
Some more notes:
4th gen calipers us 45.5mm pistons, which have no aftermarket support that I could find.
5th gen calipers use 48mm pistons which apparently are used by Porsche 911 calipers and come in anodized stainless versions.
Old 12-31-2019, 04:13 AM #5
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
I feel the problem is half the piston, and half the bore. So they both need coated.
I've just replaced mine. Again. And have been thinking along this same idea for when I need to replace again.
Sub'd.
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 06:23 AM #6
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Haven't needed to replace a caliper yet, but I'm all for bullet proofing everything I can. Count me in. I have several machine shops and coating and plating shops that I do regular service for. I could likely get this done in exchange for services and keep the price low, especially if there is a decent volume on it, depending on the approach used. What about cerakote? Not sure final thickness, but if it's only a couple of thousandths, it wouldn't be a problem to get pistons either machined from scratch or turned down to allow for tolerance.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 02:05 AM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Truly Fixing Seized Calipers
Old 01-02-2020, 12:04 AM #8
Originally Posted by Ed_C View Post
+1 what I plan to do if I ever need to replace mine again.
Old 01-02-2020, 12:22 PM #9
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
are the pistons polished, or chromed?
years ago I had a customer with a 79 corvette. those cars have terrible issue with the pistons seizing up, due to lack of use. the cars typically get parked much more than they get driven.
anyway, he was doing a full restore on it, and knew it would be sitting for a long time. so he sent the calipers off, and had stainless sleeves pressed into the bores. apparently it was at a company knowing for dealing with that issue. it cost him a lot, well over $1k for this work.
when it came time to get the car out on the road again... he had the same old problems. some pistons were seized and others were leaking. the extra prep work on calipers made zero difference..
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 12:57 PM #10
Inv4drZm's Avatar
Inv4drZm's Avatar
Not sure on that one, some have said they are chrome plated, and that seems the norm elsewhere the more I do research so they probably are.
But assuming the pistons are already chrome plated, I would only really need to coat the calipers.
Cerakoting is very popular and some websites offer caliper coating services pretty cheaply, and it's thin enough it can be applied everywhere and comes in any color.
DLC is stronger though if I can find a place that will do calipers for the right price.
Old 01-18-2020, 12:24 AM #11
Inv4drZm's Avatar
Inv4drZm's Avatar
Couldn't get a quote from anyone for DLC coating, but got one for Cerakoting.
I asked if they could do the piston bores and potentially the pistons since they are prone to seizing. This is what he had to say:
"I would advise to not do the pistons and the bores if there is a known problem."
I'm still not sure why not, the coating is only 1 thousandth thick? It should only help right?
For 4 calipers it will be $60 each.
Old 01-20-2020, 12:23 PM #12
Inv4drZm's Avatar
Inv4drZm's Avatar
Does anyone know if the remanufactured semi-loaded caliper options out there have as good of pistons as OEM? I believe OEMs are chrome plated. Has anyone seen aftermarket last as long as OEM? I might just swap out the pistons for OEM if they are better, I can buy an OEM piston to compare with.
Old 01-21-2020, 11:33 AM #13
Piggity Piggity is offline
Piggity will become famous soon enough
I'd look into a different caliper altogether since the 4th and 5th gen calipers are steel aren't they? Take a look at Lexus IS350 calipers.
I know on the 1st gen Lexus IS300 forum I'm on they have a guy selling 2nd gen Lexus IS350 caliper adapters (look up 350phi on IG) that bolt onto the IS300. The rotor width and diameter is similar to the 4runner so I'm sure it could physically fit, plus the caliper is aluminum. Obviously it would require someone creating an adapter.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 11:57 PM #14
Found out if oem is chrome plated?
Old 08-14-2020, 09:04 AM #15
Inv4drZm's Avatar
Inv4drZm's Avatar
Not sure.
brake , dlc , pistons , reasonable , tin
Coated Brake Claipers Ruthven13 4th Gen T4Rs 14 06-14-2018 11:30 AM
Powdercoat Brake Pistons or Bores? ZiaMan General Discussions 3 12-09-2017 03:37 PM
Frozen Brake Caliper Pistons? zerowkul98 5th gen T4Rs 0 10-24-2017 09:40 AM
Quick question about stuck 2 of 4 pistons in brake caliper. kacper 4th Gen T4Rs 12 04-13-2015 10:19 PM
Front brake inboard pistons 4RunnerConvert 4th Gen T4Rs 4 08-01-2011 08:24 PM
