Closed Thread
Old 01-01-2020, 03:05 PM #1
SSt4r's Avatar
SSt4r SSt4r is offline
SSt4r is on a distinguished road
SSt4r's Avatar
Need help: sunroof re-install
Looking for some help with the sunroof re-install. I had an issue where it got stuck open (right side would start to close, left side was stuck). I took the assembly out, freed it (think I found it had gone past the bent tab "stop" at the rear of the track), cleaned the track & am ready to put it together.
I found 2 small rubber pieces, marked "L" & "R" but don't know where they go. Where the L & R are marked is rectangular measuring about 3/8" by 1/2". The inverse is an odd shape. I couldn't find these pieces listed in the diagram of the sunroof in the manual. These don't appear to be the sliding shade stops shown in the diagram; they are still in place in the rear drain trays.
Ay thoughts?
Help is appreciated as I'd like to re-assemble & install before I forget how to do it!
Need help: sunroof re-install-img_1437-jpg
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
SSt4r is offline
Old 01-01-2020, 05:24 PM #2
weaves weaves is offline
weaves is on a distinguished road
You were on the right track but looking at the wrong end. Those are the rubber stops on the front of the sunshade tracks/rails.
weaves is offline
Old 01-01-2020, 06:26 PM #3
SSt4r's Avatar
SSt4r's Avatar
On the right track? Pun intended?
Thank you Weaves for the help, you are correct. Don't remember taking them out, must have fallen out & I was lucky enough to even find them.
So they go on the inside edge of the track, between the track and the front tray that has the front drains & that the motor is attached to. There's an angled notch in that front tray they fit into & the odd shaped back side fits in grooves in the track. Not sure what the purpose is: a stop? a seal?
Case closed!
SSt4r is offline
Old 01-01-2020, 09:18 PM #4
SSt4r's Avatar
SSt4r's Avatar
Just want to update this with an image showing exactly where the piece goes in case someone else runs into this issue.
It's the small angled rubber piece right at the und of the pen. The rest is already seated in the track. The imprinted "L" is facing to the left (front of vehicle); mating against the plastic
Need help: sunroof re-install-dsc02346-3-jpg
SSt4r is offline
Closed Thread
found , marked , rear , sunroof , track
Sunroof drains clogged, sunroof doesn't work. Silicone? thezentree 3rd gen T4Rs 8 06-09-2017 10:31 PM
Has anyone done a JDM NON-sunroof field monitor install? starclassic 3rd gen T4Rs 7 05-01-2017 04:11 PM
left open sunroof at beach = bad time! (sunroof maintenence Q's) SOHC-IT07 3rd gen T4Rs 10 02-25-2014 12:48 AM
Sunroof install Aceverette 4th Gen T4Rs 3 04-12-2011 07:59 PM
