Old 01-05-2020, 04:12 PM #1
808Sport's Avatar
808Sport 808Sport is offline
808Sport is an unknown quantity at this point
808Sport's Avatar
P0420 Error
My 2005 4Runner Sport V6*is throwing an error and I downloaded the freezeframe data. Could you please help me determine if it is the catalytic converter or the oxygen sensor?
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 47.843 %
Engine Coolant Temperature = 190.4 °F
Fuel Trim Bank 1 Short Term = -3.906 %
Fuel Trim Bank 1 Long Term = 2.344 %
Fuel Trim Bank 2 Short Term = -6.25 %
Fuel Trim Bank 2 Long Term = 5.469 %
Engine RPM = 1,824 rpm
Speed (OBD) = 59.03 mph
Timing Advance = 20.5 °
Intake Air Temperature = 77 °F
Mass Air Flow Rate = 35.45 g/s
Throttle Position(Manifold) = 25.49 %
Run time since engine start = 441 s
O2 Sensor1 Equivalence Ratio = 1.058
O2 Sensor5 Equivalence Ratio = 1.021
Distance travelled since codes cleared = 23.612 miles
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,489.1 °F
Catalyst Temperature (Bank 2,Sensor 1) = 1,489.1 °F
Catalyst Temperature (Bank 1,Sensor 2) = 1,325.66 °F
Catalyst Temperature (Bank 2,Sensor 2) = 1,325.66 °F
Voltage (Control Module) = 13.593 V
Engine Load(Absolute) = 49.02 %
Commanded Equivalence Ratio(lambda) = 1.053
Relative Throttle Position = 6.667 %
Absolute Throttle Position B = 59.608 %
Accelerator PedalPosition D = 28.627 %
Accelerator PedalPosition E = 44.314 %
End of report.
Thanks in advance,
Scott
Sent from my SM-N950U using Tapatalk
Scott
2005 4Runner SE V6 4X2
Galactic Gray Mica/Dark Charcoal
808Sport is offline   Reply With QuoteReply With Quote
bank , catalyst , engine , fuel , temperature
P0420, what happens if you do nothing? HappyHooligan 3rd gen T4Rs 3 12-11-2019 03:20 PM
P0420 2ndhandyotaman 3rd gen T4Rs 35 03-17-2018 10:39 AM
p0420 mikeya 3rd gen T4Rs 10 10-03-2011 12:37 AM
P0420 - Replaced A/F after P1130/1135 a few months ago... now P0420 low ?? Bank 1 Headly 3rd gen T4Rs 19 01-23-2011 08:52 PM
P0102, P0430, P0420 error codes a77boy Problems & Warranty Issues 3 03-09-2007 06:27 PM
