Old 01-06-2020, 04:05 AM #1
derekl123's Avatar
derekl123 derekl123 is offline
Real Name: Derek
derekl123 is on a distinguished road
derekl123's Avatar
Real Name: Derek
CV Axle Clunk over Bumps
Been dealing with a CV clunk, most noticeably on left side best duplicated when driving over the reflective bumps on roads and on hard dirt roads. Since I've heard the clunk, I've so far replaced both CV's (with CVJ reman), did the ECGS needle bearing, oem lower arms , oem cam bolts, oem left steering spindle, inner/outer tie rods and torqued all suspension and noise still occurs. Been living with it but is especially annoying when on hard dirt roads.
Noise sounds just like this video when driving at speed and is able to be duplicated hitting the CV where it goes into the front diff with a rubber mallet. I've taken off my sway bar and the noise still happens. Would the fix just be to replace the front diff at this point? Anyone else had a similar issue? Will try to set up a GoPro and record the noise this week.
2008 4Runner Sport V6 4WD White
derekl123 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 09:55 AM #2
CJFONNER CJFONNER is offline
CJFONNER is on a distinguished road
Many folks have had a similar noise occur coming from the front brake pads moving within the caliper. A new set of pad springs typically resolves the issue. Sounds like you’ve replaced most everything. Would hate for it to have been something so simple - but if you’re like me, a noise like that cannot go unfixed.
Try replicating the sound by driving over the reflector bumps, but riding the brake pedal ever so slightly. If the noise is gone, you’ve found your issue.
CJFONNER is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 03:19 PM #3
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
I am in a similar boat and curious to see your results. Like you, I have replaced CV's, installed the ECGS bushing, LCA's & bolts, sway bar end links, calipers/pads/rotors are new, I did UCAs when I did my suspension a year ago, etc. The only thing I have left on my current list is replace the sway bar bushings despite the fact that the ones installed look ok. I haven't gone so far as to remove my sway bar, you're ahead of me there. I was hoping the ECGS bushing would solve it, since there was noticeable play in the left CV shaft where it mates with the diff, but no dice.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
clunk , diff , noise , oem , roads
Clunk in the back, underneath, when I hit bumps Rancho5 3rd gen T4Rs 11 12-31-2018 02:12 AM
Intermittent clunk/clank over bumps zach1288 4th Gen T4Rs 15 09-27-2018 11:17 AM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Clunk Over Bumps SureShot516 4th Gen T4Rs 24 12-11-2017 01:47 PM
New rear end clunk/thump when going over bumps mpaquette 5th gen T4Rs 5 11-20-2014 10:16 PM
Copyright © 2019
