Old 01-06-2020, 01:49 PM #1
baker baker is offline
baker is on a distinguished road
V8 vibration full throttle after suspension refresh
2004 V8 with +250k miles and OME 2.5" lift with front level kit & diff lowering kit.
The lift has been in for nearly 4 years no issues.
Right before Thanksgiving I ordered parts to complete a full suspension refresh.
LCA (Beck/Arnley)
CV axles (Cardone HD)
Wheel bearings (B/A)
Tie rod ends
Sway bar bushings & end links
Rotors & calipers
UCA (SPC) location g.
ABS sensors& wires
Everything is new except knuckle & strut/springs.
After alignment, I'm getting a bad vibration only during hard acceleration from 0-40 mph. Only during throttle; not breaking or coasting. Turning has no real affect on it.
Replaced the CV axles 3 times, replaced the UCA twice (from Rocky Road Outfitters to the SPC), and replaced the wheel bearings twice. No change.
Had a local shop pull the rear drive shaft out, same vibration.
I'm thinking of pulling the front drive shaft.
Any thoughts?
Sent from my SM-N975U using Tapatalk
baker is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:55 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
LCA (Beck/Arnley)
Tie rod ends
Rotors & calipers
ABS sensors& wires
Any thoughts?
Probably has nothing to do with it, but those caster #s are terrible. You want more like 4+. Also probably unrelated but maybe rotate tires and see if any change occurs.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 02:40 PM #3
Yeah, balance and rotated...
I went with the SPC UCA so I could go to a 0°
Here is the alignment with the first set of UCA installed...
Old 01-06-2020, 03:35 PM #4
Real Name: Michael
Real Name: Michael
Just noticed you had a diff drop...a lot of people have complaints about those actually causing weird vibes. you may want to take it off and see if it goes away
Old 01-06-2020, 03:42 PM #5
Real Name: Michael
Real Name: Michael
Also why would you want a 0 degree caster....thats no bueno. Camber is what you want at 0.
It is true that having low caster at the UCA is a good thing if you're worried about scrubbing the rear of the wheel liner area, but I would recommend at a minimum 3.5 degrees of caster. Most do this through the LCA by maxing out the adjustment all the way "forward".
YouTube
My recommendation is spot "C" on the SPCs and then max LCAs out as shown in video. Dial in the Camber up top via the SPC ball joint slide. Adjust toe as needed.
Driveability will be exponentially improved. Even if you think its "just fine" now
Old 01-07-2020, 02:35 PM #6
YouTube
awesome video. I do get some rubbing in reverse on the front of the fender liner. hmm..
Also, could i have my outter CV nut too tight?
Old 01-07-2020, 03:58 PM #7
Real Name: Michael
Real Name: Michael
Also, could i have my outer CV nut too tight?
No I don't think that would cause it/be a possibility.
axles , drive , replaced , shaft , vibration
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
full suspension refresh process roadster-nh Maintenance/Detailing 3 11-13-2018 03:30 PM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
Full front end refresh wake_rider 3rd gen T4Rs 3 06-28-2017 12:46 PM
2014 Refresh or full over haul pics released!!!! 20034RunnerV84x2 5th gen T4Rs 3 04-18-2013 02:47 PM
