Old 01-06-2020, 02:42 PM #1
Kilo_ Kilo_ is offline
Real Name: Kris
Kilo_ is on a distinguished road
Real Name: Kris
ISSUE: Constant Power to Outlets
Hello friends,
Yesterday I completed the full-time 115v/12v mod after following the guide found on Toyota 4Runner Constant Full Time 115V Power Outlet Mod
The issue I am having is the guide requires you to cut the Yellow-Red stripe wire that goes to pin #6 on the 115v switch. After cutting the wire and connecting the jumpers according to the instructions, I now have an issue of other functions not working when the ignition is on.
Currently "Off" when engine is running: Turn signals don't function, climate control doesn't power on, Climate control display doesn't turn on, rear view mirror doesn't power on.
It's as if all the accessories no longer function properly but the outlets function with ignition on/off and the radio turns on when ignition is on.
Any thoughts/Suggestions?
Thanks in advance,
Kris
2008 V8 Limited
1997 V6 4WD SR5 (Blown head gasket)
Kilo_ is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 06:52 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Did you confirm all the fuses for the associated items are still intact? Perhaps you shorted some fuses in your pursuit?
Old 01-06-2020, 11:18 PM #3
Real Name: Kris
Real Name: Kris
That was my first thought but all fuses checked out fine. Really curious if anyone else has down the full-time power modification and the steps they took to accomplish it... I'll have to revert back to the original setup until I can figure this out.
2008 V8 Limited
Old 01-07-2020, 12:17 PM #4
Bumbo's Avatar
Bumbo's Avatar
You have a lot of important things not working… any chance you damaged anything in the fuse block / power distributions areas? Many seem unrelated to this circuit.
This modification has you doing some sketchy things in a very sensitive area of the car… I have my own methodology when doing work to OEM electrical system, and I generally try and avoided making changes at or upstream of factory circuit protection.
Old 01-07-2020, 06:52 PM #5
Real Name: Kris
Real Name: Kris
Yeah it seemed pretty sketch considering the outcome but the source seemed credible. Was definitely user error on my part.
I took some time last night to put everything back to stock. Once back to stock configuration I checked everything that hadn't been working... it still wasn't working. After going back through the fuses, for the second time, I found that my IG1 15A fuse was blown. Don't know how the hell I missed it.
I re-did the modification with the fuse replaced, everything works perfectly now.
2008 V8 Limited
Old 01-08-2020, 12:19 AM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
So I'm guessing you originally did the modification without disconnecting the battery?
The battery should always be disconnected when doing most all electrical work that involves wire cutting/splicing/disconnecting, etc., failure to do so risk frying ECUs and other very expensive components.
2004 Limited V8
function , ignition , issue , power , turn
Constant 12V power outlets Kmvreter Engines / Suspension / Wheels / Tires / Audio / Accessories 155 07-31-2022 02:28 PM
Mod: Add Constant and Accessory Power Outlets NH_T4r 4th Gen T4Rs 6 05-08-2018 04:11 PM
power outlets not producing full charging power outgolfin0 4th Gen T4Rs 9 10-14-2013 12:39 PM
X-post: "Constant power" to 12v outlets done! Martinjmpr 4th Gen T4Rs 0 11-05-2012 02:53 PM
Added power ports to 1992, constant power surfcitylocal Classic T4Rs 4 07-21-2010 10:44 AM
