Old 01-08-2020, 04:16 PM #16
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Body Mount Relocation Kit - NTK FabWorks
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 07:43 PM #17
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by That_Titanium_4RNR View Post
Nice! Little more work than the Relentless one but it looks really nice and clean once done.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 02:39 PM #18
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
Originally Posted by duffdog View Post
Its just not going to happen. Nobody has ever installed 33's on a 4runner and not had them rub on the frame when off roading. Forget the sway bar and body mount, even after all of that is done the 4runner can turn so sharp that the actual frame hits the tire. There just aren't people who can say that they have done it without rubbing. Even if you are doing something as simple as going up a driveway and turning, either the tires will rub or you do not have 33's, its that simple. 285's are not 33's, they are slightly smaller. 33's are 33x12.5x17.
If you are bored, go ahead and type in the tires size to see the difference here:
Tire Size Comparison
I am literally telling you I ran 255/80/17s (a 33.1x 10.2 inch tire) for over 4 years with no body mount chop and no rub. I mapped the Red Clay Rally 2 of those years, and it wasn't until I went with a 285/75/17 that I required a BMC.
Also, you can't just say "285s aren't 33s, they're slightly smaller" I don't believe you are understanding how tires are measured because 285/75/17 is a 34x 11.1 inch tire.
So yes, you CAN run "33s" with the correct wheel offset, lift and ucas and a little know how. I aND many others are testament to this.
I cleared 33s easily running a Dobinsons MRR lift, no sway bar, ICON UCAS and a caster adjustment as far forward as possible. (Usually 4 to 5 degrees forward).
Nothing else required. 34s are when it becomes required.
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 02:40 PM #19
Originally Posted by techno View Post
Are you saying get the caster at 4°, or forward 4° more than spec, which would put it at 7°13'?
Total caster was between 4 and 5 degrees
Old 01-18-2020, 03:53 PM #20
Drift Monkey's Avatar
Drift Monkey Drift Monkey is online now
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Which UCAs can push out 4-5 degrees? I always read people getting 3 maybe 4 degrees, but I always figured more was better in this case.
I may or may not do a bmc after my lift and 33s, but I always figured enough caster along with 0 offset wheels would be plenty to avoid it.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is online now   Reply With QuoteReply With Quote
Old 01-18-2020, 05:06 PM #21
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
SPC adjustable UCAs should be able to.
Old 01-19-2020, 12:46 PM #22
little_titan little_titan is offline
little_titan is on a distinguished road
Saw this a while ago and saved it to my notes for reference, hope this helps.
“Thanks to gaterose for providing the following information.
What does it take to fit x tire with x lift?
Front/Rear Lift Tire Size
Stock -
265/65R17
265/70R17* (except BFG A/T)
1/0
265/70R17* (31.6x10.4)
255/75R17 (32 x 10)
2/1
265/70R17
255/75R17
3/2
275/70R17 (32.2 x 10.8)
285/70R17† (32.6 x 11.2)
255/80R17* (33 x 10)
3/2 + 1-1.5" Body Lift
255/85R17† (34 x 10)
285/70R17†
305/65R17† (32.6 x 12)
* requires removal of mud flaps and probably minor trimming
† requires trimming and may require body mount chop (click here for details on body mount chop), upper control arms, and/or increased backspacing.
Add 5 to the middle number for 16" wheels, subtract 5 for 18" wheels (265/75R16=265/70R17=265/65R18)
The above assumes you're using stock wheels and no wheel spacers. Aftermarket wheels or wheel spacers will increase rubbing, more trimming will need to be done in order to fit the listed lift height.”
little_titan is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 09:47 PM #23
T4rcruznn T4rcruznn is offline
T4rcruznn is on a distinguished road
It’s possible I am currently running 285-70-17 Falken Wildpeak AT tires on ET 0 4.75 BS wheel with 3” icon lift with SPC UCA’s without a BMC. Just had to trim fender liner.
T4rcruznn is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 03:45 PM #24
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
255/75/17 Kumho AT51 here on FJ wheels (15mm offset) and 2" lift = almost no rubbing except reverse full lock on one side...
hinmo24t is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 08:08 PM #25
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
33's must be 12.5 inches wide or they are not 33's. What is so hard to understand about that concept? If they are not 12.5 inches wide they are "weenie european range rover pizza cutter tires" which is what you have. Also, 285's are STILL not 33's and you yourself mentioned that they rub and they are not even big enough to call 33's yet.
33's without the Body Mount Chop-33s-vs-pizza-cutters-jpg
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 08:31 PM #26
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
That's just ****ing stupid. Pizza cutter width or 12.5 width, they are both 33" tall, therefore 33s. Where do you get the idea they "have" to be 12.5?? Just because it's your concept doesn't make it fact. Get over yourself with that bullshit.
Pizza cutter 33s probably wouldn't need a BMC with the right wheel offset and might be the better option for anyone not wanting to do one. To each their own.
Old 01-20-2020, 09:20 PM #27
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
I got Pizza cutters 33" no bmc. It's like saying that if Ferrari is not red then its not Ferrari, or like someone i knew that used to say that if you turbo your golf and its not 20pounds of boost don't tell anyone that it is boosted.
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 10:49 PM #28
Its not my concept. Its been that way since off road tires were invented Mr. "xtreme wheeler"...lol! You simply cannot buy a 33.153x10.324x17 tire anywhere.
Its what keeps people from being confused. As an "xtreme wheeler" you should know that already. Oh wait, you have a rooftop tent - you should change your handle to "xtreme overlander"...
2005 Blue SR5 v8
Old 01-20-2020, 10:53 PM #29
No it isn't. Its like having a ferrari with a 4 cylinder engine, which makes it not a ferrari even though from the outside it appears to be one. Or having a 4runner with a chevy motor - not a 4runner anymore even though it appears to be one from the outside. Same concept.
2005 Blue SR5 v8
Old 01-20-2020, 11:06 PM #30
benztech82's Avatar
benztech82's Avatar
If measuring tape is at 33" .......it's a f..ing 33", X10 or by 12.5 has nothing to do with hight of a tire. The size you describing is a simply a start point for a truck/tractor tire from when you and me weren't born yet. Simple as that.
33s , avoid , bmc , lift , mount
Body Mount Chop?? Doozi 4th Gen T4Rs 16 05-04-2023 09:21 AM
Body Mount Chop FactoryRide 5th gen T4Rs 39 02-18-2017 02:50 PM
Need body mount chop in OC Ttn333 So Cal 14 06-25-2015 06:00 PM
Body Mount chop vs LR UCA Aquabear 4th Gen T4Rs 14 10-24-2014 10:51 PM
Body mount question ( not a body mount chop) crashman 4th Gen T4Rs 1 09-30-2014 01:57 AM
