Wanted to share my experience with the TRD Pro suspension in case others decide to pursue this option. I found the complete suspension including UCA's, rear arms, panhard locally for $1k off a 200mi 2016 TRD Pro. The modifications listed below are the only items I had to change, the TRD Specific part numbers are detailed as well. This is only intended as a reference document, I'm assuming you know how to install suspension, if not there are a number of forum threads and youtube how-to's available that cover that.
Donor Vehicle: 2016 4Runner TRD Pro
Recepient: 2008 4Runner SR5 V8 4WD
Difficulty: Moderate, suspension experience recommended.
Tools:
Large Impact (numerous bolts required this)
1/2" Drill or similar (or a hand file if you're patient enough)
Heavy Duty Floor Jack (I used 3.5 Ton)
Heavy Duty Jackstands
Small jacks - For misc lifting to position parts
Metric tool set - flex head ratchets recommended
Saw/Grinder or similar - For trimming the front shock eyes down
Hex Set - Required for remote reservoir and sway links
Required Modifications:
Rear shock upper mount hole:
Existing - 7/8"
Required - 1"
Front shock lower mount:
Existing - Too Narrow by about 1/8 - 1/16
Action - Trim sides of shock eyes
Parts Details:
UCA - Same as non Xreas
Rear Lower Links - Same
Rear Upper Links - Same fit, but thicker eyes
Panhard - Same fit, but thicker, tapered bar
Rear Springs - Slightly thicker, 1 additional coil
Left Front Shock PTR13-89160-LF
Left Front Spring PTR13-89150-AA
Right Front Shock PTR13-89160-RF
Right Front Spring PTR13-89150-AA
Left Rear Shock PTR13-89150-LR
Right Rear Shock PTR13-89150-RR
Ride Height @ fender lip after install: (if anyone has stock 08 4WD V8 height please share)
Front 35"
Rear 37"
Unfortunately I forgot to do before measurements so I don't have lift numbers.
The Parts
Note: I moved the front spring seats to the upper notch prior to install. Also didn't install the UCA's
Front Shock Comparison - A little taller
Rear Shock comparison - The TRD's are a bit taller
Front Shock Lower Mount Comparison - TRD is larger with thicker eyes
Front Shock Lower Mount Comparison - TRD is 1/8" - 1/16" wider
Rear Upper Links - TRD Eyes are thicker
Rear Upper Shock Mount - TRD is much larger
Rear Spring Comparison - TRD is slightly thicker and has 1 more coil
Panhard comparison - TRD is more beefy
Modifying Parts:
PLEASE NOTE! USING A 1" DRILL BIT TO WIDEN THIS HOLE CAN BE VERY DANGEROUS, USE CAUTION!!!!
Alternated between 1-1/8" step bit and 1" regular using light pressure so the bit didn't snag and break my wrist.
It fits! Also note the hole for the alignment tab and resevoir already existed.
The front shock is too wide for the mount. I decided it would be better to trim the shock instead of the mount to retain the mounts original strength.
Gently trim/grind back about 1/16" of material on each side. I tried a grinding wheel, but found the cutting blade in horizonal position worked best.
Fits perfectly now. Be sure to alternate sides when trimming and ensure symmetry
Ride height after completion and test drive. Will grab better shots later...
