Old 01-09-2020, 02:52 PM #1
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix
Hi All,
A little background from me. I am an ASE certified tech of 16 years. I just picked up a 2004 4Runner v6 to have a little fun with on the cheap. I decided to give it a few weeks of driving to give it a proper shakedown and see what it needs to get back up to snuff before I dump some money into fun things.
I am glad I did because after my first longer drive (I work 3 miles from home)...I came back to the shop with P0420 and P0430 codes.
Shame on me. I did scan it at the shop prior to purchase but in my haste I did not check to see if monitors had run. I am fairly convinced the PO cleared the codes and knew I wouldn't likely complete a drive cycle on my road test. He was right.
So here we are. I have codes for both converters on a Cali emission car. Great.
Not 100% convinced I needed cats, or knowing how long this problem existed prior to my purchase. I decided to put 2 downstream O2 sensors in and see what happens. They looked old, old enough to be original. So I swapped them out. I was happy as at first the CEL stayed off. But within a day or 2 it was back. Frustrated I started researching CARB compliant Catalytic converters for the car. Not shockingly I was unhappy with the cost.
Upon installation of the O2 sensors I did notice the flange for the Cat was rusty and potentially leaking, even if just slightly and not enough to make the vehicle loud or smell exhaust in the cabin.
If you've been reading waiting for the fix portion here it is
I got a gasket that goes between the cat and y-pipe for each side.
a little heat to the nuts and it all came apart easily. Once apart it was clear how smoked the old gasket were! The driver's side didn't look all that bad before taking it apart.
I replaced the gaskets and drove the vehicle for 2 full drive cycles. So far so good. I did check the monitors and and catalyst monitors did pass. So fingers crossed that it doesn't come back but I hope this post help anyone struggling with Catalytic Converter efficiency codes.
If anyone has these codes I highly recommend checking the conditions of these flanges/gaskets. The proximity of the sensors to the flanges makes it easy for intrusive air to affect the readings.
Cheers,
Pics below
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200108_113402-jpg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200108_113409-jpg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200108_114404-jpg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200108_120550-jpg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200108_120554-jpg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-20200109_123607-jpg
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 03:29 PM #2
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Could you add the part number here if you have it?
djpope09 is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 03:36 PM #3
Warwicke36's Avatar
Warwicke36's Avatar
I used a Napa gasket which was "EXH 31332"
I will repairlinkshop.com to get the OEM part# in a little bit and edit this post.
So the OEM part appears to be 90917A6005
But the Toyota diagrams suck to pull gasket numbers as they aren't shown in the illustration.
Old 01-09-2020, 05:53 PM #4
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
nice!
would go check mine
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 05:57 PM #5
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Thanks for posting this!!!
Checking and fixing exhaust leaks should be the first step.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 06:10 PM #6
Honda pc Honda pc is offline
Honda pc is on a distinguished road
Nice.. Keep us updated when and if codes comes back.. I am fighting a 420
Sent from my SM-N960U using Tapatalk
Honda pc is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 06:44 PM #7
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
When the flanges are that bad a little Permatex 81878 works great.
SaulG is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 08:05 PM #8
Warwicke36's Avatar
Warwicke36's Avatar
I use a product called acousti seal. It's a vulcanizing goo (technical term haha) that has a lot of good applications. I will probbaly throw some on there just to protect it from water and salt intrusion. Cheers
Old 01-10-2020, 02:20 AM #9
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Originally Posted by Warwicke36 View Post
Hi All,
Cheers,
Pics below
Yea Mine has a big leak and I can see the exhaust smoke from both sections here and I think I’m beyond the point of put a gasket and call it a day. Might need to buy a whole new exhaust? Anything else I should check? Do while I’m down here?
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-de6596a1-49db-4728-9283-d490bcc999af-jpeg  Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix-fe3bf110-9a14-46dd-9b32-f2000ad51a5f-jpeg
BigMike18 is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 08:45 AM #10
Warwicke36's Avatar
Warwicke36's Avatar
BigMike
Those flanges are definitely in rough shape. But I don't see any reason not to try a gasket and some acousti seal first. It looks like someone has already been in there as they have through bolts instead of studs. If you have access to a torch I would heat those up and get it apart and asses it then. If it doesn't seal completely you're no worse off then you are now. The gaskets were only $3 each. The other thing you can do if you have access to a grinding wheel (I sometimes just use a cut off wheel on its side because its so thin you can get it in a lot of tight spots) you can grind down the ears (part the bolt goes through) so that the flange is flat all the way across. That way when you tighten it down the ears don't bottom out first before the gasket has a chance to squish and seal up. Just be careful not to mangle the inner pipe that protrudes past the flange.
There are a couple of shade tree ways to get past the bad flanges too but let's not get too carried away yet.
As far as what else to look for... I would look the frame over for soft spots. You can use a small hammer to tap away on spots that look suspect. Looks like you might have some fluid leaks going on as well. Doesn't hurt to try to figure out where that is coming from while you're under there. Cheers,
Old 01-10-2020, 02:33 PM #11
Warwicke36's Avatar
Warwicke36's Avatar
So far so good. I have put way more miles under more driving conditions than it ever went between CEL status before. Monitors are all showing OK on the scan tool. So I am very optimistic at this point. Now I can put my money into getting rid of X-REAS and upgrading to Bilsteins.
Old 01-10-2020, 04:47 PM #12
MikeinNH67's Avatar
MikeinNH67's Avatar
Mine leaked there too and the flanges looked like some of these pics. I replaced the gasket but it only lasted a few months. I then bought new flange pieces and welded them on plus went with a more solid gasket. Been quiet so far (since September) but wonder if the driver's side is now leaking as I get a p0430 about once a month.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-10-2020, 04:52 PM #13
Warwicke36's Avatar
Warwicke36's Avatar
That sucks, New England roads are tough on cars. I see you're in NH I'm in Maine. I go to NH often to hike. Not happy the mountains are getting ice and rain this weekend. This winter has been lame for winter hikes.
Old 01-18-2020, 03:19 PM #14
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
Thanks for the info!
I already replaced one CAT 3 years ago (PO430) and now im wondering if it was the just the gasket? I also got a PO420 a couple times in the past 3 months so I will have to check/replace the gasket before I buy another California CAT.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 11:06 AM #15
ZeroByte ZeroByte is offline
ZeroByte is on a distinguished road
Thanks for this! I will have to give it a shot. I am dealing with an intermittent P0430 (comes on, clear the codes, it goes away for a month, then comes back).
ZeroByte is offline   Reply With QuoteReply With Quote
back , codes , drive , monitors , vehicle
Video - Tackling The Dreaded P0420 (Catalyst Efficiency Below Threshold) shadow247 3rd gen T4Rs 2 03-27-2014 10:54 AM
From the dealer, converter bank 2 below efficiency. Passenger side. Jeff T 4th Gen T4Rs 4 02-05-2014 07:15 PM
p0420 cat converter vs. 02 sensor evowned 3rd gen T4Rs 17 04-06-2012 01:36 PM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 3 06-07-2011 08:18 AM
Catalytic converter P0420 Please help Nimphius27 4th Gen T4Rs 2 06-06-2011 11:08 PM
