03-25-2007, 05:24 PM
rear window & key remote
HI:
Just bought my first Toyota, 2007 Limited v6. I can't get the keyless entry button to roll the window up or down. I have tried the inside window control and it works fine. I have also checked to see if the window control on the driver's door is off. The keyless remote just does not work. Any fixes or suggestions?
03-25-2007, 05:43 PM
Re: rear window & key remote
Originally posted by paradox998
HI:
Make sure you are holding it down until the car beeps and the window rolls all the way down. You cannot roll the window up with the remote.
03-25-2007, 05:50 PM
this only a feature on the limited 07? sport or sr5?
___________________________________
2007 4Runner Sport Edition V8 4x4 (8686)- Millennium Silver
Equipped with: Sunroof (SR), Rear Spoiler (RF), Side Airbags (GY), Double Decker Cargo (CM), JBL 10spkr Radio (EJ), Homelink (NJ), Electrochromatic Rearview Mirror (EC) and Daytime Running Lights (RL). Also installed are the Weather Tech Extreme Front and Rear Floor mats, Venture Shield front end protection, 30% front tinted windows, Garmin Nuvi 660, Yakima Pro 16s roof cargo box, Masterbuilt Aluma Haul, custom made full cargo area rubber mat and an Autopage RS-1000 remote starter/alarm with 1mile range, perimeter sensor, window mods, and glass breakage sensor.
Mods soon to come: Jaos CP with Challenger H4's,
03-25-2007, 05:53 PM
Thanks for the quick response. When I hold the window button down on the remote I do hear a beep after about a second, but the window does not move.
03-25-2007, 06:15 PM
Hmm. Interesting, it seems like either the setting is turned off or something is wrong. If its a big deal take it to the dealer...
03-25-2007, 06:23 PM
Make sure you don't have all the windows locked out with the driver's side door switch on.
03-25-2007, 06:45 PM
You may have to initialize the power window first, which would also give you one-touch capability for the button on the dash.
1. "Unlock" all of the passenger windows, if you have that button pushed in on the driver's armrest.
2. Press and hold the dash button to lower the rear window completely.
3. Press and hold the dash button to raise the rear window completely.
That should be it.
The lockout button for the passenger windows will not prevent you from lowering the rear window with the remote - it will only stop the button on the dash.
2006 Limited V8 4x4, Shadow Mica/Stone
03-25-2007, 07:14 PM
I tried cycling all the windows, including the rear window. No effect. I guess the dealer will have to reprogram the remote. Clearly the dealer did not check the vehicle thoroughly before delivery.
03-25-2007, 09:08 PM
Super Moderator
Super Moderator
Nope -- all 4th generation models.
2003 SR5 V6 4WD Titanium with cladding
03-25-2007, 09:10 PM
Did you try what is in toto's post? If it beeps when you hold down the remote, then the remote is working and it just needs to be reinitialized.
03-25-2007, 09:42 PM
Yes, I just tried that again and no luck. I am open to any ideas.
03-25-2007, 10:03 PM
Figured it out. Thanks for the lead Toto. To re-initialize the window you have to put the rear window down half way and then back up, holding the button in for a few seconds. Taking it down and up alone won't do it.
Thanks for the help.
03-26-2007, 08:22 AM
Sorry about that... that's what I get for thinking I remembered it, rather than going back to the TSB and checking.
The TSB (Back Power Window Initialization, PG021-02) does say that what I posted above is correct except for step 3:
3. Press and hold the dash button to raise the rear window completely, and continue to hold the button for one second.
I'll add that without the rear window being initialized, your rear wiper and rear defroster don't work, either.
11-13-2007, 01:19 AM
Thank you All.. I tried it and now everything are back.
05 - Titanium Silver Sport Edition V6 4X2
02 - Acura TL Type S - Aegean Blue
http://i73.photobucket.com/albums/i2...RSignature.jpg
02-21-2020, 11:45 PM
Any ideas when the rear window won't re initialize? Tried everything to re program the auto features for the rear window and it won't work also key hole and fob only crack the window a little bit.
