Old 01-11-2020, 02:56 PM #1
jeffsGT7 jeffsGT7 is offline
jeffsGT7 is on a distinguished road
Climate control issue
Hoping someone can help us here.
2009 SR w/90k
Issue is that Heat is on or off (if fan is on and 65+ degrees it's ON, move the temp to LOW is it's OFF).
Fan works great, A/C is fine, just a PITA managing heat (esp. here in Michigan).
Thanks
jeffsGT7 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 04:35 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
2009 SR w/90k
Thanks
When you say "LOW" are you saying lowering the temperature setting lower than 65 degrees via the center control or pushing LOW on the control on the left?
2004 Limited V8
Old 01-11-2020, 05:37 PM #3
toyorgy toyorgy is offline
toyorgy is on a distinguished road
Heater hot or cold, nothing in between ~ the temperature sensor became unplugged.
toyorgy is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 01:58 PM #4
the temp setting ... so I push "down" from 65* and it says low.
- sorry for my delayed reply on this
Old 02-22-2020, 02:00 PM #5
Thanks- I will look for it!
So is this the ambient temp sensor (under the hood)?
or is there an interior temp sensor?
Old 02-22-2020, 02:15 PM #6
scw1991 scw1991 is offline
scw1991 is on a distinguished road
I gave the sensor located in the panel just below the ignition switch a good cleaning. It definitely helped. These T4Rs really crank out some heat!
scw1991 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 02:41 PM #7
Real Name: Skip
Real Name: Skip
It's the "Cabin" air temperature sensor, it's located behind the dash panel below the ignition switch, look for the little slotted holes, the holes and or sensor can get clogged or covered in dust causing it to malfunction, if so cleaning the dust should solve any issue with the sensor if it has a issue or as mentioned it may have a loose connection.
2004 Limited V8
fan , great , heat , issue , pita
Climate control issue , unable to change the airflow RocksRunner 3rd gen T4Rs 5 01-05-2020 08:36 PM
04 Limited Climate Control issue nicheel8 4th Gen T4Rs 6 10-21-2016 05:08 PM
2006 limited climate control issue JEL 4th Gen T4Rs 4 11-17-2015 09:59 PM
Climate Control Issue smallfry 3rd gen T4Rs 1 08-01-2011 12:35 AM
Climate Control Issue After Kenwood DDX418 Install rtuck1 4th Gen T4Rs 11 05-22-2011 11:47 PM
