Old 01-12-2020, 01:21 PM #1
NVSmythe NVSmythe is offline
NVSmythe is on a distinguished road
Front driveshaft removal help
2003 4wd limited
I have a bad u joint I’m trying to replace on my front driveshaft.
I’ve got the front separated from the front diff and the drive shaft compressed.
I have the nuts off the flange connecting the driveshaft to the transfer case. The bolts appear to be pressed into the flange on the transfer case.
I looked like I should be able to slide the driveshaft off the bolts and maneuver it out between the cross members.
BUT... I have separate the driveshaft from the transfer case.
I’ve tried driving a pry bar between the flanges, hitting it with a BFH, putting the pry bar between the times and hitting that with a BFH to pop them apart.
The things isn’t moving a bit.
Am I missing something? Or just hit it with more PB blaster and try again later?
Any ideas?
NVSmythe is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 03:03 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Originally Posted by NVSmythe View Post
2003 4wd limited
Any ideas?
Are you using a deadblow or a real metal hammer?
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 02:35 AM #3
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
THIS. Just did all my u joints today. Smack that sucker with a hammer a couple times and it should pop out. Make sure the shaft is fully collapsed or it won't come out past the cross member
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
bolts , case , driveshaft , front , transfer
2WD Driveshaft removal Toyoter 4th Gen T4Rs 6 06-13-2021 11:28 AM
Driveshaft removal Mellemel 3rd gen T4Rs 1 01-22-2015 09:47 PM
Question re: U-joints and driveshaft removal 92Pony 3rd gen T4Rs 7 12-08-2014 10:22 AM
Driveshaft Removal... Mel0 3rd gen T4Rs 31 12-17-2013 07:36 PM
help with driveshaft removal Jc12 3rd gen T4Rs 6 05-20-2012 11:59 PM
