Originally Posted by xtremewlr
Wut?
My '03 2UZ has a dip stick, right next to the oil dipstick. If I'm not supposed to use that for checking the ATF level, then shoot some links for the proper procedure.
Originally Posted by Drift Monkey
The 5sp tranny is "sealed."
See my post below.
I have a 2003 with the 2UZ V8. It has a trans dipstick and a drain plug on the trans pan. To my knowledge, all 4Runner with the 2UZ V8 had the 5 speed.
The 2003 V8 has the newer 5 speed transmission and yes it does have a dipstick but it's not the sealed version of the 5 speed and I'm pretty sure using a different fluid than the sealed versions, 2004 and onward V8s and 2005 and onwards V6s have the sealed 5 speed transmission,
xtremewlr
so yes you can check your fluid level using the dipstick, you only have a drain plug on your trans pan, all the sealed 5 speeds have a drain plug and a fluid level plug on the bottom of the pan, I would much rather have a dipstick because it's sorta a pain to check the fluid level on the sealed transmission.
