04-20-2014, 09:27 PM
265/70/17 owners, wish you've gone bigger?
I'm in the market for new tires(Goodyear Duratracs) just not 100% sure what size I want. I'm thinking about the typical 265/70/17 with Daystar 2.5/1.5 mainly because of cost and MPG.
Any of you all that have 265/70/17 wish that you would have gone bigger(with bigger lift)? Like 285/70/17?
04-20-2014, 09:31 PM
Real Name: Matt
Real Name: Matt
I think if I had that much lift I would, I installed a 3/2 for a while and had to bump it up to 275s. Also have seen others regret not going bigger when lifting more than just to level.
Seems like a lot of people are pretty happy with 265s and 2.5/1.5 or 3/2 though. Maybe others will chime in.
edit - 285s might be a tough fit with only 2.5/1.5
04-20-2014, 09:47 PM
I think about it sometimes but I think i really just need spacers so some wider wheels with a lower offset to get the look I would happy with using 265s. I would hate to take more of a MPG hit than needed for my pavement pounder.
Current - 2016 Mag Gray SR5, 3rows - diode dynamics fogs, tint, FalkenAT3W, blacked out badges, more to come
Old - 2008 Black sr5 v6 - Bilstein 5100s, FJ rears, black counter steers, xenon depot h11 hid kit, Scion Radio upgrade (touchscreen), BHLM, tint, Cooper AT3s.
04-20-2014, 09:54 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
wish I did 255/85/16s or 285s. short answer, yes.
04-20-2014, 10:24 PM
skinny tires for the win.
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
Real Name: Sam
Real Name: Sam
i swapped my barely worn 265/70/17s for 285/70/17s. So yes.
04-20-2014, 10:49 PM
Real Name: Scott
Real Name: Scott
I for one am extremely happy with mine; Bfg all terrains. They're not to small, even after the fj swap. My gas mileage was almost unaffected and I am able to keep up with the guys running much larger tires when we're on the trai. I haven't had traction problems on or off road.
04-20-2014, 10:51 PM
Real Name: Will
Real Name: Will
I'm running 265/70/17 and currently in the market for 285's. I like them a lot and they were a big upgrade from the factory tires but I've found I want to go a bit taller and run a more aggressive tire.
2007 Sport Edition 4WD - Build Thread
04-20-2014, 10:58 PM
I love my Toyo Open Country M/Ts. I found the right offset wheel and only had to remove the bottom half of my fender liner to fit LT295/70R17 (33X11.50R17) with my Cornfed 3/2.
I get constant compliments on how the tires look and usually don't need any help in the mud holes or on the rocks.
04-20-2014, 11:07 PM
Personally, I can't really say I wish I have gone bigger. I stayed with 265s because I chose an aggressive tire (Duratacs). Of course when I see pictures with 285s I think it looks great, but I'm not in a position right now where I can afford to lose a few more MPGs just to have a wider tire. I think with my wheel offset, and because the tire is aggressive, it looks pretty good. I get compliments all the time, and a lot of people assume they're 33s (I find myself correcting people a lot). Maybe in a couple years when I'm not daily driving my 4Runner, I'll go up in size.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
04-20-2014, 11:08 PM
Real Name: Leonard
Real Name: Leonard
I know my next set of the off road ones will be taller. Don't get me wrong, the 265s do really well and tend to get me into enough trouble.
Went to these due to, can fit in the spare section.
Having fun's build
04-21-2014, 12:10 AM
I went 265s on my 2014 and not regretted it. Going to give them a run for a while. Then in 5 years or so when they are fairly shot I'll decide if I want to go taller.
But I'm only a casual to moderate offroader, no giant rock crawling or anything at this point ;)
And yeah, not taking a hit on the MPGs has been awesome... Maybe when I'm retired and don't have a 50- mile commute every day to pay for
04-21-2014, 06:18 AM
Sometimes I wish I had just stayed with my 255-75-17's. Now that Cooper has the ST Maxx that would be a great aggressive AT tire that still has good road manners.
Running 285-70-17's does look good, but you lose some low end grunt along with the few mpg. Not to mention with my lift, the 285's and the BajaRack I have just under 0.5" clearance getting into my garage.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
04-21-2014, 06:42 AM
The 265s have been good to me but I do wish they were taller. They look small to me now. I planning on some 255/75/17 for the next tire. If we didn't drive it so much, I might even lift it more and stuff some 255/80/17s or 285/70/17s under there. 275/70/17s may also be a good size.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
04-21-2014, 07:16 AM
BFG AT's in 265 on my '03 for a couple of hundred thousand miles and years of Colorado offroading. No regrets on the 265 size at all even with a 3" lift. Different trails in different places, bigger might have been better but it just never turned out to be necessary for me. YMMV.
Current ride: 2014 4Runner Trail Premium in Super White, BFG AT T/A KO's 265/70-17, Extreme Outback Portable compressor (100% Continuous Duty), Staun tire deflators, Safety Seal flat kit, full Husky liners Previous rides: 2003.5 4Runner V8 Sport edition in Magnetic Gray, 3" Revtek lift, BFG AT T/A KO's 265/70-17, plus all the toys moved to the 2014 above, 2001 4Runner BFG AT T/A KO's
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
