Old 01-14-2020, 04:12 PM #1
werminghausen werminghausen is offline
werminghausen is on a distinguished road
Just bought a 2003 4R with 190K and V8, leak at back of transmission
I just bought a 'new' 4th Genration 4R. Engine is very smooth.
Alls seems to work (except for the brakes- they suck, need to rebuild calipers) but there is a big leak at the output side of the transmission... it is dripping from something that looks like an electrical attachment facing the rear of the car, not sure where the leaks is exactly. It is not the output shaft. It could be a seal from the rear of transmission to that el attachment? It is dripping down from that attachment
Is there a notorious leak point?
Need some help.
I can take a picture if this is easier.
Best, Martin
Just bought a 2003 4R with 190K and V8, leak at  back of transmission-2020-01-14-14-55-30-jpg
werminghausen is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 04:24 PM #2
Here in the fist picture you see the drop hanging at the lowest corner of the attachment (don't know a better word). And from there it is dripping to the floor.
Also few pictures of the car.
It is overall in good shape despite the rust on a New Englander car.
The car needs to be lifted a bit, new tires and new brakes will make big improvement.
These boards on the side rather suck, they need to go as well.
The most annoying parts at this point however is the transmission leak down there.
Thanks for helping me out.
Martin
Just bought a 2003 4R with 190K and V8, leak at  back of transmission-2020-01-14-14-56-05-jpg  Just bought a 2003 4R with 190K and V8, leak at  back of transmission-2020-01-14-14-55-20-jpg  Just bought a 2003 4R with 190K and V8, leak at  back of transmission-2020-01-14-14-57-27-jpg  Just bought a 2003 4R with 190K and V8, leak at  back of transmission-2020-01-14-14-58-03-jpg
Old 01-14-2020, 04:28 PM #3
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
tcase or actuator leak im pretty sure. did you see it before buying it? could have probably worked the price a bit better if so. good luck, there are a lot of threads on the subject from this forum i believe.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 04:44 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Agreed, actuator leaks. You should get under there and clear really well to pinpoint where the leak is coming from but plan on having some work to do to replace the seals.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 04:56 PM #5
Thanks,
So this attachment is the 'actuator'. Actuating what? HI LO gears or locking differentials?
Yes agreed I need to clean that area.
Do you guys have a diagram showing the parts and seals (and part numbers) needed for the repair?
Cheers, Martin
Old 01-14-2020, 04:57 PM #6
No I didn't see this problem when buying. I paid 4300 for the car...not too crazy.
Martin
Old 01-14-2020, 05:23 PM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Originally Posted by werminghausen View Post
Thanks,
Cheers, Martin
Yes, the actuator is for selecting hi/lo and locking the center differential.
I think there is a sticky with links to the service manuals above. You can also look online - Toyota Parts Center Online | Genuine Toyota Parts & Accessories
Old 01-15-2020, 11:26 PM #8
Still need help
Meanwhile I understand that I need to remove the TC in order to remove the Actuator. Leak is through the connecting rode and or large round gasket at black plastic housing backside. Pain in the neck and a day of work....if everything goes fine.
Where can I get a good diagram to better understand the parts that fall on the floor at one point?
And a list of parts (gaskets and seals ) to buy from Toyota to do a proper job?
I have a car lift and basic tools around and I have worked on cars a lot... I am just not familiar with Toyota and this new 4R.
Martin
Old 01-16-2020, 02:03 PM #9
ZLJUANN ZLJUANN is offline
ZLJUANN will become famous soon enough
Still need help
Martin
I used the blue devil stop leak when mine developed an insane leak from there. Basically the seals dry up from lack of use.I believe the blue devil "rejuvenates" the seals, buying you some time. my leak was really bad and it stopped altogether.
Pour the stop leak in, fill the rest with the right gear oil, drive it and actuate all the modes until it stops, drain and replace with the right gear oil. Use the actuator periodically. This was my solve while not the "correct" solve. It was also a 200k mile 03 that I bought for 4k to beat on, so ripping the tcase apart was not an option for me.
Now if we were talking about my 06 v8 4wd long travel rig, I think I'd do the seals.
ZLJUANN is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 01:26 AM #10
SolRayz's Avatar
SolRayz SolRayz is offline
SolRayz is on a distinguished road
SolRayz's Avatar
I'm currently trying AT-205 reseal on mine. So far so good. I will say my actuator leak is not as bad that.
-----Marc-----
2003 V8 Limited 4WD
SolRayz is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 08:11 PM #11
Thanks, that is at least worth to try out. $20.
Mine is beater.... I just found a huge rust hole at the driver floor panel..ohmy...
So I need to weld this poor thing and then come back to the actuator.
Martin
Old 01-21-2020, 04:09 PM #12
drallan drallan is offline
drallan is on a distinguished road
TL;DR
Agreed its the TCase actuator. This is the thread I would follow. I haven't done it yet, but have all the parts and this is where I would start. Fixing the transfer case shift motor leak from within..
Long story:
I manged to induce the leak (i'm assuming) when I test drove the car. I bought it from a private seller, a nice couple in their early 30s who I would assume used it for their weekend hiking and biking adventures, so I wasn't too concerned about getting scammed. It was an 04 v8 w/ 178k when I bought it. First inspection looked good. No visible leak, and under carriage didn't show any signs of a recent cleaning so I was confident there wasn't a leak. It had recent MD inspection (very through) and fluids looked good. On the test drive I made sure to exercise all the 4wd modes to ensure the actuator worked after reading some of the use or lose threads on here. Worked like a champ bought the truck, no issues. A month later I notice a tiny drop on the driveway and after some research I figured out where it came from. Could be coincidence, but I'm assuming I probably introduced a tear or something in the o-ring when I used it. I contacted the previous owner and inquired about it, and she insisted that she never used the center diff lock, and was frankly afraid of the button.
The point of this long story is that this was 4 years ago. I'm not sure how bad your leak is, but I haven't fixed mine. It does leak a bit. I tried the Blue Devil stuff once, but probably less than I should of for fear of ruining the other gaskets. It did appear to work for a while, but leak has since returned and I haven't' tried more. Stop-leak seams to be a hit or miss fix. I just keep a cheap gallon of gear oil on hand and periodically check and top off the TCase and before long trips, but it never takes more than 1-2 pumps before it starts oozing out the fill hole. I do think based on the size of the drops in the driveway that it is getting worse. I actually have all the gaskets, just haven't taken the time to try and replace them.
drallan is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 07:00 PM #13
WacoCharlie WacoCharlie is offline
WacoCharlie is on a distinguished road
Common problem on 03. There are updated parts. At some point after 03 those parts were installed in production. At the time I did my 03 only Lexus sold the updated stuff in a kit. My 05 never had an issue.
My 4Runner-05 Sport V8-360K+ miles
WacoCharlie is offline   Reply With QuoteReply With Quote
attachment , bought , dripping , leak , transmission
2003 V6 Transmission Leak ToyotaBrah 4th Gen T4Rs 2 02-26-2019 08:12 AM
Just bought a 98 with engine in the back Soupdaddy New Members 1 08-08-2013 09:32 PM
i'm back!, Bought my second 4Runner!!! :D CAD_GA1390 4th Gen T4Rs 16 04-02-2013 09:29 PM
New, just bought my 2003 4Runner agboise New Members 22 11-09-2011 09:44 AM
Back in action, Just bought... imryannn 3rd gen T4Rs 15 04-03-2009 01:28 AM
