Old 01-19-2020, 12:36 AM #16
Androo Androo is offline
Androo is on a distinguished road
Originally Posted by Drift Monkey View Post
Yeah, it’s the bracket Lightwerkz sells
Androo is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 03:03 AM #17
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Hmm I guess maybe some of the aftermarket ones have a different mounting pattern for the brackets? If it’s a real pita, I could probably reuse the backs on my OEM lights and harvest the lenses from an aftermarket set. How much work was it to make the brackets work? Which aftermarket did you use?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 11:11 AM #18
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
So I got a chance to pull apart the headlights today...
At this point I think I might just be better to buy some TYCs and break those apart for the retro.
I think you might be right.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 11:19 AM #19
adkfinn's Avatar
adkfinn's Avatar
In other news, I am seriously contemplating the Morimoto MLED 2.0. Lightwerkz’ initial testing seems
to confirm they do outperform the typical (D2S 5.0/G5-R) 35w HID setups. TRS claims they are “brighter than a D2S 5.0 with a CBI and 50w ballast” but it seems Lightwerkz hasn’t quite found that to be true, not that I was really considering 50w anyway, though. They use the same mounting points as the D2S 4.0/5.0/G5 and seem to be reasonably priced so needless to say, they I’ve added them to my board.
I am curious about the newer LED units as well, but leary of the fact that they are a single unit and if your LED ever goes out, the entire thing is shot and needs to be replaced... right? (save for dis-assembly and soldering in a new emitter). That makes me less inclined to run them considering you might shoot yourself in the foot long term, or at least set yourself up for some not so easy repairs down the road potentially. I would be more inclined to consider an LED specific projector that had a replaceable LED.
Old 01-19-2020, 11:20 AM #20
On the plus side, baking them open was surprisingly easy. I just reused the stock sealant to cram em back together, but leaving it on was a huge pita to fit some of the stuff back together. I’ll be much better prepared to do the actual retro now...I think lol.
Old 01-19-2020, 11:30 AM #21
Yeah that’s what I presumed about the mounting patterns, being different across the manufacturers. The Lighwerkz bracket may have been designed on true OEM so you may be good there. As far as the PITA of it that I had to modify it really wasn’t bad at all, just a little annoying.
My tip to you is watch Lightwerkz video on YouTube. He shows the most important step which really is lighting up the headlamp and marking on walls before you do anything to it. I messed up my first time and had to redo it.
Old 01-19-2020, 11:32 AM #22
adkfinn's Avatar
adkfinn's Avatar
It was good practice for sure.
My advice - despite appearances, junk most of the factory sealant and cram that recess with new when you do the lights for real. I thought the factory grey would be enough also... and then I had to pull them off the truck to re-open and re-seal them after the first time around. I used the black butyl rubber morimoto stuff and it worked well so far and solved my 'not quite sealed' condition.
Old 01-19-2020, 04:23 PM #23
Yeah, this is a good point, and one I did consider. It's a double edged sword here, the all-in-one simplicity of install vs having to break 'em back open once they do fail to change out the whole unit. An easily-replaceable LED unit is what I'd prefer as well...but if they last long enough to make it to the next technological advancement, this may be a moot point, as I'd probably be cracking 'em open again to shove in the latest and greatest anyway. I'm gonna have to dig into this one a bit more...looks like the LED they use is a Chinese one (HML-3 7545) - not sure about the quality/longevity on that one.
The other downside is that any/all LED proejctors out there are probably outside of my preferred color range and probably not high CRI.
I'm gonna go with the TYCs, which I believe are direct factory replicas - so we'll see once I get them open.
I'm guessing you mean mounting/aiming/lighting it all up before you permanently seal again? Good tip.
Oh 100%! I just crammed at all back because the water damage done to them in some areas was beyond salvaging. I plan on cleaning the crap out of whichever housing backs/lenses I decide to use - any tips for that? Seems like a heat gun on low and a lot of tedious peeling...doesn't sound fun. I plan on buying a roll of RetroRubber while I'm at it as well.
Old 01-19-2020, 08:12 PM #24
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
even if you use the aftermarket lights, you keep the stock internals and swap over if necessary, its good to use it for parts when certain parts break, you can also swap the lens over or shroud over. just take your time and do it right.
heres what s2000 projectors and 50w and cbb bulbs can do, camera is a google pixel 2 xl auto setting.
Retrofit suggestions/advice?-50865284_10161284289535704_3969755013751767040_o-jpg
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 09:37 PM #25
CrimsonCountry's Avatar
CrimsonCountry CrimsonCountry is offline
CrimsonCountry is on a distinguished road
Attachment 352615
Nice! Good height on the purple shift too. Did they do any lense spacing/tuning for that specifically or a happy bi-product of your setup?
I still love my S2K retro I finished last year. I've been running crap bulbs and Lexus Denso 35w ballasts so might switch that up soon. At minimum, I'll get some CBB or night breakers.
Sent from my SM-G955U1 using Tapatalk
2006 SE 4.0 4WD (click for build) : Custom, de-badged floor mats...
CrimsonCountry is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 11:44 AM #26
riceandpho's Avatar
riceandpho's Avatar
lightwerkz did the retrofit for me, clear lens was stock, only mod i did was the bulb spacer mod, which help make it a little brighter, i used a 16 gauge bare solid wire to make it space about 1mm at the bulb area. 2mm and you will loose intensity.
im at least 120+ feet from the loading dock.
Old 01-21-2020, 04:46 PM #27
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
I've seen someone retrofit G5-EXLS using those CB&D brackets, said he had to grind some of the inner shroud to for clearance.
Old 01-21-2020, 04:53 PM #28
Nice. Looking at the EXL beam pattern though, I kinda dislike all the foreground spill. The intensity is pretty incredible though.
I wonder how the Lightwerkz brackets compare to the CB&D. $55 for the CB&D vs $70 might tip the scales though haha.
Old 01-21-2020, 08:18 PM #29
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
The ones Lightwerkz sells are from CB&D, odd there's such a large difference in price.
I'm going to retro my parents' GX470 with EXLs in place of the projector highbeams, will be making foreground limiters for them.
Old 01-21-2020, 10:00 PM #30
Hmmm...that is strange.
Sounds awesome! How do the foreground limiters work. I'd been interested in following your build!
projectors , retrofit , shrouds , suggestions/advice
Advice please: Rear diff locker retrofit to a diesel gen 3 pavelvoivoda 3rd gen T4Rs 3 06-30-2019 01:57 AM
Headlight Retrofit service suggestions FortCollinsT4R General Discussions 18 11-19-2017 10:27 AM
Advice and suggestions knox4rner2014 5th gen T4Rs 12 11-14-2014 01:59 PM
New HU help/suggestions/advice... bronchogg Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-18-2011 06:03 PM
Advice on 1st Retrofit hulk311 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-13-2010 06:56 AM
