01-21-2020, 10:20 PM
#31
Real Name: Ed
Real Name: Ed
Originally Posted by Drift Monkey
Hmmm...that is strange.
Sounds awesome! How do the foreground limiters work. I'd been interested in following your build!
Probably won't be any time soon LOL I still need to get cracking on a retro for my 3rd-gen and get my 4th-gen back on the road, which has a pair of retrofitted headlights ready to install
Foreground limiters are just shields mounted at the upper half of the projectors Official: Morimoto Mini D2S 4.0 - HiDplanet : The Official Automotive Lighting Forum . Even some OEM HID projectors have them, the Lexus RX330's for example.
01-21-2020, 10:23 PM
#32
Originally Posted by adkfinn
I used NGK G5-R's and the pre-made brackets. The G5-R uses a threaded shaft and is D2S
If I were to throw one of those threaded shaft bi-xenons into the reflector high beam on my 07's, would I need to do much by way of aiming, or would that be pretty close to the factory low beam projector's cut off?
01-21-2020, 10:52 PM
#33
Ah I see! It looks like that'd help quite a bit - thanks for the link. The RX350 projectors are quite nice from what I've seen, especially when tuned correctly.
I'd assume they'd aim decent since they'd thread into the shaft - probably would have to widen the hole though. They also make a high beam specific projector that works pretty well for that, but from my research, a good LED bulb in the stock reflectors can pack an even bigger punch.
2006 4Runner Sport Edition V8 4WD
01-22-2020, 01:27 AM
#34
Originally Posted by riceandpho
even if you use the aftermarket lights, you keep the stock internals and swap over if necessary, its good to use it for parts when certain parts break, you can also swap the lens over or shroud over. just take your time and do it right.
heres what s2000 projectors and 50w and cbb bulbs can do, camera is a google pixel 2 xl auto setting.
Attachment 352615
gotta love that s2000 glass
2006 4Runner Sport 4WD V8
Ti Silver|TRD OR Wheels|Bilstein 4600|Dobinson C59-599 Rear Spring
01-22-2020, 11:04 AM
#35
Real Name: The Native Explorer
Lots of good info on here.
@ Drift Monkey
if you haven't decided on a projector yet, the 'moto D2S 5.0's are killer for the money. I threw some Hi-lens LED from Profile Performance in the high beam bucket and a pair of XBAleds for DRL - output is fantastic for lows and wild with quad highs. Definitely would reccomend the TYC housings, but they are fun to open with the butyl they use! Let me know if you have any q's.
https://www.toyota-4runner.org/3418145-post210.html
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
01-22-2020, 11:24 AM
#36
@ Drift Monkey
Yeah its between the 5.0s or the G5-R (or BRT) if I end up going HIDs.
Any tips with opening the TYCs? I remember reading through your thread and you had a fun time getting all the butyl off lol.
I read through some of your thread while researching and your build came out awesome! Nice job man!
01-22-2020, 12:13 PM
#37
The ones Lightwerkz sells are from CB&D, odd there's such a large difference in price.
x2 - can confirm. The brackets I received from Lightwerkz were CB&D. I assumed the price diff was re-seller markup...
2007 4Runner with some crap on it. Nice crap.
01-22-2020, 12:22 PM
#38
I used the pre-cut brackets/mounting plates from CB&D (bought through LightWerkz) and didn't have any issues during aiming... but I only addressed the vertical and didn't do any left to right aiming. Overall my retrofit ended up pretty close to the factory projector aiming.
I am sure there are levels of projector tuning I haven't addressed also. My beam pattern cutoff is kind of two steps from left to right, with the right currently a little higher than the left (the lower section of the right meets the higher section (above the step) of the left). It doesn't bother me much to be honest but I might mess with it in the spring.
01-22-2020, 01:28 PM
#39
Right on.
To be honest, I wouldn't use the oven with the TYC's unless you want to concern yourself with melting stuff you don't want to melt. The heat gun and a pliers seemed to be the safest way of getting that gray garbage out of the cracks. It takes time - at least, on my set it did. I hear that people open them up with no issues after 8 min in the oven, but after 15 minutes, mine didn't budge. Nice thing is, any deformation to the housing from prying the lens off is easily formed back into shape with heat, and is hidden once put back together and installed!
IG @apohl17
01-22-2020, 02:44 PM
#40
Right on.
Interesting...I actually tried the heat gun method and it was a major PITA compared to the oven for me. The waterlogged OEM housing I had separated in like 7-8 minutes. What temp did you try for the TYCs?
My TYCs actually got delivered today from RockAuto, now if I could only decide wtf to retro in them...lol.
01-23-2020, 11:23 AM
#41
Oof, I don't honestly remember. Might be in my build thread, I'll check. 300 maybe? Should have been enough.
IG @apohl17
01-24-2020, 06:31 PM
#42
Welp, I said f it, and am going with:
G5 Stage III Parts Package
Bixenon Projectors: G5-BRT (3")
Compatible Ballasts/igniters: Hylux A0050 (45W) W/ D2S Adapters
D2S HID Bulbs 2S: Osram 66240 Nightbreaker Laser (4200K)
Shroud Style: No Shrouds Required
Wiring Harness: (match stock bulb size) HD Relay: H11/H9/H8
Headlight Sealant Gray: RetroRubber
03-09 4Runner D2S 5.0/G5-R Brackets
I actually forgot to add 2x High Beam Splitter (Single) Version:9005 Male > 9005/9006 Female, so hopefully they can add them in before shipping so they'll ship free with the rest of the stuff. The shipping is steep for small stuff.
At the end of the day, I really want to stick to a more neutral color temp...6000k just isn't appealing to me.
01-24-2020, 10:09 PM
#43
Good Stuff!!!
You are going to enjoy that setup I am sure. Check your PM
01-25-2020, 03:03 AM
#44
Good Stuff!!!
I think so too.
I got no PMs bro.
01-25-2020, 08:50 AM
#45
I think so too.
I got no PMs bro.
Awesome. Is your avatar from Ahh real monsters?
Looking forward to the light setup. I'm going to get auxbeams for my 2004 TYC soon. Just low beams lol
