Old 01-17-2020, 01:10 PM #1
Byte Me Byte Me is offline
Byte Me is on a distinguished road
Curious leak from Sun glasses holder
Wondering if anyone else has experience this - when it's really raining and I've been parked outside a couple times when I get in I noticed a bit of wetness in the cup holder area. When I started driving water streamed out of the corner of the sunglasses holder. The holder itself and my sunglasses within were dry. Once the majority of the water had poured onto my leg and cup holder area it was done dripping.
I'm assuming it's coming from the sunroof - perhaps a clogged drain tube?
Alternately it could be from a rust spot directly above the middle of the windshield I guess but I navel jellied that area after sanding and painted it - doesn't look like it rusted through.
Anyone else have an idea or experience with this?
Byte Me is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 02:01 PM #2
cbailey1523 cbailey1523 is offline
cbailey1523 is on a distinguished road
It's likely that it's coming from the sunroof. Put the sunroof all the way back and see what it looks like in there. Rust is the likely culprit. I had a Honda did that to me years ago.
Sent from my SM-G975U using Tapatalk
cbailey1523 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 03:05 PM #3
DMX512 DMX512 is offline
Real Name: Ben
DMX512 will become famous soon enough
Real Name: Ben
There are weep holes in the 4 corners of the sunroof.
GENTLY push some weed eater line from the sunroof down towards the ground. There are barbed coupling in line from my understanding.
I happened to have a large syringe that I could gently push some water through afterward to check that the line was clear.
2007 SR5 v6 4x4
Black
17" wheels
200000 miles
Constant 12v Mod / TPMS Mod
DMX512 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:32 PM #4
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
This...
Or if you're like me and have access to shop air use that.
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:18 PM #5
Thanks for the replies. Once it gets above single digit temps around here I'll give this a try and report back.
Old 01-17-2020, 06:01 PM #6
Spriter's Avatar
Spriter Spriter is offline
Spriter is on a distinguished road
Spriter's Avatar
I had this happen to me. In my 4runner i do NOT have a sunroof though.
The root cause for me was that the sealant between the windshield and the frame had rotted and began to rust the metal slightly (and this is where the water would collect, and eventually drip into the sun glass holder and finally on to the center console area once that filled).
In my case, the windshield had several cracks on the top side of it, so i had it replaced at the same time as I had it resealed.
That said, IF YOU HAVE A SUNROOF, check your drain hoses from the sunroof before looking into windshield seals as i understand those hoses are a common cause for water dripping in the cabin as you describe (but only if you have a sunroof)
Ive attached a photo here showing where the rust and the subsequent leak occurred (circled in photo).
Imgur: The magic of the Internet
05 V6 4WD, 2" OME lift, Falken AT3W
Spriter is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 04:04 PM #7
Ugh - that's what I'm afraid of. I've got rust along and under the rubber strip on the top of the windshield. Will try the drain hoses first but I fear this is what I'm dealing with as well.
Thanks,
Brian
area , cup , holder , sunglasses , water
Sun Glasses Clip? Mick1 5th gen T4Rs 20 12-30-2019 04:04 PM
Wear your Safety Glasses! Dous General Discussions 20 03-23-2018 12:51 PM
FS:Knives, glasses, holsters-Wichita, KS flyboysgt For Sale: Non-T4R Items 14 01-08-2015 11:44 AM
Oakley Glasses for Sale BlackYotaSport3 Classifieds - buy & sell (no commercial ads please) 2 11-17-2010 12:51 AM
Map Lights and Glasses Compartment AlexJet 4th Gen T4Rs 2 09-01-2005 07:15 PM
