Old 01-17-2020, 06:16 PM #1
rodsrunner rodsrunner is offline
rodsrunner is on a distinguished road
Front rotors
Were there two different sizes of rotors used on the front of 2004 SR5 4Runner 2-wheel drive? If so why?
rodsrunner is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 07:22 PM #2
djpope09 djpope09 is offline
djpope09 will become famous soon enough
The only rotor differences I'm aware of are between the 16 and 17 inch wheels. The rotor size should be based on wheel size, not 2x4 or 4x4.
There are also 3 different brake calipers (WG, WH, and WL). If you have original calipers, the two letter combo is cast in the caliper, near the bottom.
djpope09 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 07:40 PM #3
Ralphman's Avatar
Ralphman Ralphman is offline
Real Name: Kyle, But you must call me dragon
Ralphman is on a distinguished road
Ralphman's Avatar
All sr5’s have the smaller rotors
All sports have the bigger rotors
Some limited have the small rotors and some have the bigger rotors
Do it for dale
Ralphman is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:59 PM #4
Real Name: Skip
Real Name: Skip
That is unless a previous owner changed out the smaller rotors for the larger rotors.
2004 Limited V8
Old 01-18-2020, 07:12 AM #5
Ralphman's Avatar
Ralphman's Avatar
True, that’s what I did
Do it for dale
Old 01-18-2020, 11:46 AM #6
I do have the 17" wheels but not sure about the rotor size.
Old 01-18-2020, 11:56 AM #7
dont all 4th gen 4runners have 17" wheels? every sr5 ive seen has them & all sports, & limiteds have 18"
Old 01-18-2020, 01:21 PM #8
A friend has a 2004 SR5 V8 4x4 and his has 16'' wheels.
Old 01-18-2020, 02:37 PM #9
Ralphman's Avatar
Ralphman's Avatar
Front rotors
Good chance you still have to smaller brakes that came from the factory but the only way to truly know is to measure the rotor or look at the casting on the back of the calipers if your concerned that some one put sport brakes or the 5th gen brakes. The rotors are noticeably different when next to each other. I’d say look at your brake lines and if doesn’t look like anyone has been in there messing with them, if it looks untouched you still have the small brakes, going to be the easiest way to tell with out taking the tire off and measuring the rotor or removing a caliper to look at the casting number.
Do it for dale
Old 01-18-2020, 04:55 PM #10
ok, maybe that was a early year vs later year thing? i looked at a lot of 4runners recently when looking to buy one, & all the 06-09 sr5 & sports i saw had 17".
Old 01-18-2020, 09:24 PM #11
Real Name: Skip
Real Name: Skip
The rotor sizes on 4th Gen T4Rs are 319mm and 338mm, if you don't know which you have either take the wheel off or simply crawl under the front and measure them the best you can, the 319mm is a tad over 12 1/2" @ 12.559", the the 338 is just under 13 3/8 " @ 13.307" so that's a tad over 3/4" @ 0.756 difference in the 2 sizes, so you should be able to tell the difference just by getting a tape measure relatively close to the rotor.
If you do have 16" wheels you have the smaller rotor.
2004 Limited V8
2-wheel , 4runner , drive , front , rotors
Front rotors... Majindan 3rd gen T4Rs 4 02-03-2014 02:58 PM
Front Rotors Res957cue 4th Gen T4Rs 5 06-12-2012 03:58 PM
Front Rotors 319 mm or 338 mm??s h7009 Maintenance/Detailing 6 03-09-2011 02:49 PM
Possible to "downgrade" the front 13.3 rotors on '06 ltd to the 12.6 rotors flippedman 4th Gen T4Rs 0 05-08-2009 11:33 AM
How about front rotors? Sad4RunnerOwner Problems & Warranty Issues 1 04-01-2004 03:30 AM
