Old 01-18-2020, 12:05 PM #1
WacoCharlie WacoCharlie is offline
WacoCharlie is on a distinguished road
Sun/moonroof replacement
First of all thanks to this forum I found the TSB...just no pictures but oh well. Kind of a big job but I have my parts ordered and everything out and on the ground. Parts at half price, labor free and it is still over $1,000 to fix! Ugh..but I love her so no problem. Getting close to 400K so I don't mind fixing, She has been the best vehicle I have ever owned. Last two years I have had to replace exhaust manifolds and power steering rack. That's pretty much it in 24 plus years.
My 4Runner-05 Sport V8-360K+ miles
WacoCharlie is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 12:15 PM #2
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Sub'd. I'm going to be doing the same this spring, so don't be afraid to document the process!
The post below is the most thorough overview I've found, but I'm not sure what kind of setup you'd need to bench-test it outside the vehicle as he does.
4th Gen Sunroof - stuck in open position/grinding motor sound - SOLVED!
Did you source new OEM parts or scavenge them off salvages/etc.? What issue were you having that is prompting the remove/replace?
eleven14 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 07:19 PM #3
New factory oem sub assy and cable assembly. I’ll check that link out. Thank you so much I’ll take all the help I can get. Good luck finding GE factory tape for sunroof loom. That’s another story. You’re only a few bolts away from mount unit so just bench test they’re. I guess. All of a sudden motor was clicking and roof started binding. Upon disassembly the R cable was junk. Almost all hinged parts were loose too. It rattled prior. The new stuff is much tighter. It’s taking a week ind half to get parts but I shod just ordered the sub assembly the first tine. I’ve got my motorcycle and gfs car for back up. It’s a big job. Dealer quoted me 2 to three hours to put cables and sub assembly together on bench. Which s fair considering the time spent. $130 an hour and ice got time on my hands!
Old 01-19-2020, 11:51 PM #4
villaphoto's Avatar
villaphoto villaphoto is offline
villaphoto is on a distinguished road
villaphoto's Avatar
I've done a full Sun Roof Assembly replacement. Honestly, your best bet is to keep an eye out for junk yards with a 4th gen sunroof assembly. Instead of following the TSB to replace a piece of it, I just dropped the head liner and the whole unit. Bolted the new one in, plugged it in, and it was ready to go.
I will say that it's a pain in the butt to pull the headliner out, but we had the whole thing out and back in in about 3-4 hours.
villaphoto is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 01:45 PM #5
Yeah, sounds like the best approach rather than trouble-shooting mine further. Motor is good and it slides fine, just makes the crunching sound when fully open which is likely a seized cable on one side. If I can grab a full working unit from a donor, the swap should be straightforward.
How'd you source yours? A main site like car-part.com or just calling/monitoring local yards?
Old 01-20-2020, 02:08 PM #6
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
This is why I hate sunroofs. I never use mine for fear it will fail someday.
ktom3001 is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 12:25 PM #7
NWTrailRunner NWTrailRunner is offline
NWTrailRunner is on a distinguished road
This happened to my wife recently while she was with my son who randomly asked to open it. Luckily it wasn't raining (WA state) and my wife was able to fiddle with the mechanism enough to get it closed. This is a good reminder for me to see if there is a breaker I can pull out to prevent any accidental openings until I get this replaced. Thanks!
2003 4WD Sport Edition V8; 3rd Gen Tacoma Suspension Swap with Bilstein 1.75" rear springs
NWTrailRunner is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 12:36 PM #8
You can disconnect power to the motor (behind the sunglass holder) pretty easily. I'd just unplug it if you're worried about anyone using it.
Old 01-24-2020, 07:50 PM #9
You are 100% correct. The new OE SUBassembly I got from Middle East was broken and I’m dealing with that. I went to examine the cable set I got from same area diff vendor was in pieces when I opened. Turns out one piece for R side cable assembly was for L side. The little hinge pin that holds it in was loose and separated from assembly. And R cable was not in bag like L cable. Someone jacked with it. So I’ve spent $1100 dollars and I’ve got junk with one vendor saying “to be honest I pack real safe”. SO called a Toyota bone yard in California and I’ll have a complete assembly glass motor shade everything to my door for $300. Headliners not so hard that I can’t put a lot of $300 complete assemblies in. In the meantime my 4Runner has been down for the count. Looks like a grenade went off inside.
Old 01-30-2020, 11:19 PM #10
villaphoto's Avatar
villaphoto's Avatar
There's a Toyota salvage yard a few hours from me. I just stalk to see what 4runners they have in stock and give em a ring. Super fair pricing.
Old 01-31-2020, 07:28 AM #11
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Not to mention they will always leak eventually. I see no upside to them.
I've sealed up the one on my 3rd gen, need to do the same to the 4th one of these days. It's completely covered by my solar panel anyway lol.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 01:31 PM #12
villaphoto's Avatar
villaphoto's Avatar
Any build thread or photos of your solar panel setup? Considering going this route for my 4runner for a fridge and other electronic bits.
Old 01-31-2020, 06:52 PM #13
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Sounds like a good opportunity to get some sheet metal and weld it shut.
Old 02-01-2020, 06:40 AM #14
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Which one might that be?
royal T4R is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 02:52 AM #15
villaphoto's Avatar
villaphoto's Avatar
Rancho Toyota Recycling. Fair prices and they have photos of the vehicles they have in stock. Makes it easy to find what you need. If you give em a ring, they'll also look up parts for you and hold em/ let you pay over the phone to come pick them up.
Plus the owner has a sweet SAS'd 4th gen as well.
fixing , parts , sun/moonroof , vehicle , years
moonroof delete/removing moonroof? Vtwinracersp2 5th gen T4Rs 23 09-11-2018 03:23 PM
Moonroof or not to moonroof; that is the question! PauldF 5th gen T4Rs 74 04-17-2018 03:41 PM
Moonroof Leak kyn8 3rd gen T4Rs 30 02-11-2018 12:28 AM
What the part on my moonroof? 19964Runner 3rd gen T4Rs 2 10-21-2012 02:17 AM
Moonroof sound rabeet 4th Gen T4Rs 2 01-26-2004 09:58 AM
