Old 01-21-2020, 12:59 PM #1
bocephuss420 bocephuss420 is offline
bocephuss420 is on a distinguished road
Electrical cleaning after water submersion
I sunk the front drivers side of my 4th gen this past weekend and had muddy water up to the seat for a little over 5 minutes.
I have pulled apart all the connections I could next to the foot rest (some I can't figure out how to disconnect) and am spraying them with electrical contact cleaner.
I am curious if anyone has any advice on the best way to clean these types of connections more throughly?
https://i.imgur.com/hKiEZPX.jpg
bocephuss420 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 08:50 AM #2
cbailey1523 cbailey1523 is offline
cbailey1523 is on a distinguished road
Don't forget to use dialectric grease when you put them back together. It's win win. It gives a good moisture barrier and makes it easier to pull apart later if needed
Sent from my SM-G975U using Tapatalk
cbailey1523 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:23 PM #3
just remember, dielectric grease is not intended to be used on the actual metal to metal contacts, it does not conduct electricity. its only for the outer parts of the connector or spark plug boots to seal out moisture etc.
Old 01-22-2020, 04:46 PM #4
I've used it on every electrical connection I put back together for over a decade without issue. I've used it with the only purpose of keeping moisture out and making it easier to manipulate later. Are you saying it hurts the connections?
Old 01-22-2020, 05:18 PM #5
that's great you have used it without any issue, but if you are applying to the metal contacts that is not what its designed for. im not saying it "hurts" anything, just pointing out it is non conductive & can actually degrade the electrical connection.
i agree it helps with getting connections apart & is designed to seal out moisture when applied correctly. it can also be used for heat transfer application like a module in a distributor or even a computer CPU, but real heat sink paste is best for that.
heres all kinds of info on how to use it properly.
https://www.google.com/search?ei=Irk...4dUDCAs&uact=5
YouTube
connections , contact , electrical , throughly , water
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Engine/Electrical Issues after water crossing notfromtheuk 4th Gen T4Rs 6 05-18-2016 01:25 PM
Electrical short?? Random electrical issues? Fanman47 4th Gen T4Rs 5 06-09-2014 03:12 PM
Will a tail pipe draw water if it is barely under water on a boat ramp? jow 4th Gen T4Rs 9 05-08-2013 12:53 PM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
