Originally Posted by cbailey1523
I've used it on every electrical connection I put back together for over a decade without issue. I've used it with the only purpose of keeping moisture out and making it easier to manipulate later. Are you saying it hurts the connections?
Sent from my SM-G975U using Tapatalk
that's great you have used it without any issue, but if you are applying to the metal contacts that is not what its designed for. im not saying it "hurts" anything, just pointing out it is non conductive & can actually degrade the electrical connection.
i agree it helps with getting connections apart & is designed to seal out moisture when applied correctly. it can also be used for heat transfer application like a module in a distributor or even a computer CPU, but real heat sink paste is best for that.
heres all kinds of info on how to use it properly.
https://www.google.com/search?ei=Irk...4dUDCAs&uact=5
YouTube
