Old 01-22-2020, 12:17 PM #1
V85VV V85VV is offline
V85VV is on a distinguished road
Exclamation 2004 V6 sport 4wd differential questions. Which model Detroit truetrac to get?
Okay so I have a 2004 4wd v6 sport.
I've decided I want to put truetracs in the front and rear. But I'm having trouble narrowing down which model# is the correct fit for the front and rear?
From what I've determined to far. The 2004 v6 has as 3.91 gear ratio in the front and rear.
But I'm reading conflicting information on other things.
Some sites say 7.5" and 27 spline for the front some says 8" 30 spline.
For the rear some say it's 8.2" 30 spline a some say 8" 30 spline.
V85VV is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:19 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Front and rear for our trucks are all nominal 8".
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 02:03 PM #3
Cool that solves that question. Still not entirely sure which model # truetrac for the front and rear. Anyone know?
Old 01-22-2020, 05:43 PM #4
LT1coupe's Avatar
LT1coupe LT1coupe is offline
LT1coupe will become famous soon enough
LT1coupe's Avatar
I bought the 913A610 8" 4 pinion 30 spline for the rear. I have not installed it yet.
Can you use it in the front with an ADD differential?
2006 V8 Sport 4wd conversion, ADD front axle, FJ twin stick transfer case, premium long tubes, truetrac ,5100's, FJ springs
LT1coupe is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 02:42 AM #5
Originally Posted by LT1coupe View Post
I bought the 913A619 8" 4 pinion 30 spline for the rear. I have not installed it yet.
I'm reading conflicting info. Some said model:
913A610 for front and rear.
Some said 913A541 in the rear and 911A445 for the front.
And now you're saying 913A619.. so I'm pretty lost. Was hoping someone on here had a definitive answer?
I don't want to buy the wrong ones and find out half way into installing it.
Old 01-23-2020, 06:49 AM #6
LT1coupe's Avatar
LT1coupe's Avatar
My apologies, I fat fungered it. it is the 610
Old 01-23-2020, 11:50 AM #7
Update when you install please.
Any here who can confirm the correct model or suggest a resource to figure it out?
Old 01-23-2020, 11:57 AM #8
Inv4drZm's Avatar
Inv4drZm's Avatar
Talk with East Coast Gear Supply or Just Differentials. They can probably give you part #s and they can sell you the gears already setup to install in your truck.
Ask them if they recommend an automatic locker for the front. I bet not.
Old 01-23-2020, 12:05 PM #9
LT1coupe's Avatar
LT1coupe's Avatar
If you search "truetrac" in this forum by title you'll find a few that have installed the 610 & you'll also find at least one that didn't like the truetrac in the front.
Old 01-23-2020, 09:59 PM #10
LT1coupe's Avatar
LT1coupe's Avatar
Decided to install mine this evening, got the third member on the table and found this
Dropbox - 20200123_172543 (2).jpg - Simplify your life
This thing ran smooth as silk, no idea it was missing a tooth.
Anyway, the 610 carrier is correct for my 2006 V8 Sport. I'm picking up another third member tomorrow and will install it in that one for an outing Saturday.
Old 01-25-2020, 06:04 PM #11
LT1coupe's Avatar
LT1coupe's Avatar
I picked up another third member & the Truetrac is installed. The 913A610 is the correct one for our 4runners. I have not driven it yet because the 3rd member I picked up was from a 4wd & uses bolts on the pinion flange & mine was originally a 2wd & had studs. Guess who doesn't have the bolts?
I know I could swap the flange, but I decided not to jack with the pinion nut.
The bolts will be here next week.
Old 02-04-2020, 04:46 AM #12
According to both of them their is no truetrac model that fits the front. Only option is ARB.
I'm familiar with how it will operate off/on road I've driven different vehicles with similar setups.
The 610 is indeed correct for the rear I installed it and it works well. I searched and cannot find anyone who installed a tructrac in the front on a 4th gen. Can you advise who it was who did this?
Has anyone here installed a truetrac or LSD in the front on a 4th gen?
4wd , front , rear , spline , sport
Detroit Truetrac Limited Slip mmanuel 3rd gen T4Rs 15 05-20-2018 02:59 AM
Eaton Detroit Truetrac PN#913A610 Socal SIKHILUXSURF For Sale: T4R Items 8 02-22-2017 09:29 PM
Detroit truetrac dirtbike250x 3rd gen T4Rs 12 02-14-2014 02:30 PM
Detroit Locker vs. TrueTrac Thai Off-Roading 0 11-15-2002 08:19 PM
