Old 01-24-2020, 10:09 PM #1
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
RockAuto $56 Front LCA's, check the ball-joint
Community safety anouncment!
Seems like there has been a few front Lower Control Arm threads popping up recently.
I have had a leaking lower ball joint for a year+, bought some 555 ball joints on a closeout RockAuto was having quite a while back.
Then ended up getting a set of WhiteLine LCA bushings... after the seed was planted by another T4R member, been sitting on them for a bit too.
Then noticed RockAuto has front LCAs for $56, thinking as i am swapping out the bushings/ball-joints, i was not concerned that the bushings are not OEM.
These are UltraPower bagged, appears to be a parts close-out reseller? as far as i can tell.
I believe the Left side is a Beck/Arnley with AC Delco ball-joint. Rust starting on the inside surface, of the LCA.
The ball joint is the wrong size for the LCA and the C-clip is floating above the surface of the LCA, not safe.
Ball-Joint is a Zerk style BJ, it has "BC 0 46" in the top and the boot has #4520192A >>CR<<.
The right side looks like a SPK. As far as pics i can see. Welds look smeared on.
The blue lines are the edge markers. Can see the gap between the C-clip and the LCA is larger than the thickness of the C-clip.
RockAuto  Front LCA's, check the ball-joint-56-dollar-lcas-jpg  RockAuto  Front LCA's, check the ball-joint-large-side-jpg  RockAuto  Front LCA's, check the ball-joint-small-side-jpg  RockAuto  Front LCA's, check the ball-joint-badgreaselbj-jpg  RockAuto  Front LCA's, check the ball-joint-bad-lbj-jpg  RockAuto  Front LCA's, check the ball-joint-img_8601-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 12:25 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I recently pressed out my upper and lower ball joints and installed moog balljoints with greasable zerks. All 4 ball joints had clips that float above the pressed surface. This is normal for an aftermarket part.
The taper on the ball joint stud is what keeps the ball joint from coming loose. Not to mention the castle nut with cotter pin.
randy88fj62 is offline   Reply With QuoteReply With Quote
ball , ball-joint , front , lca , rockauto
FS: 3rd gen NEW front end hardware/lug bolts/lower ball joint located in Cinci region BADCLOWN For Sale: T4R Items 6 06-04-2019 12:28 PM
Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint tannerk15 4th Gen T4Rs 4 03-28-2017 08:53 AM
Front Shock Suggestions after 1.5 inch Front Ball Joint Specer Kit Ruger2011 Classic T4Rs 9 08-21-2016 09:53 PM
Front Upper Ball Joint - replace arm or joint? dleeallen 4th Gen T4Rs 7 02-05-2016 12:14 AM
front passenger lower ball joint keeps breaking/coming apart jsbrewton 3rd gen T4Rs 9 02-13-2011 06:22 PM
