Originally Posted by aadams330
Well that’s a relief. So best case I need 4th gen rotors. Worst case they’re right about the diff. Will check in on Monday.
You have one other possible option, if you can somehow make a sleeve/shim to get the 5th Gen rotors to truly center up they will work fine, so far I haven't read of anyone doing that but it is an option, but the shim/sleeve would have the be rather thin, if you can get them to center properly once the wheel is install they can't move off center.
Just for reference the hub bore difference is...
(5th Gens) Center Hole Diameter 107.95 MM
(4th Gens) Center Hole Diameter 106.17 MM
The difference is 1.78 MM, so the shim/sleeve would have to be half of that... 0.89mm, which is a tiny, tiny bit bigger than 1/32".
