Originally Posted by metramm
Ebola,
I had clunking in the front of my 06.
I swapped swaybar endlinks, swaybar bushings and cv axles due to torn boots.
Turned out one axle was toast and the joint inside was clunking.
After replacing them all, no more clunks.
Pull/push your cv axle to see if it has play in it. good luck!
Yes definitely checked that, tie rods, and upper suspension components. Im thinking that its the endlinks because I started hearing the noise sometime after I installed a leveling kit and there is considerable play in them. Currently trying to find extended or adjustable links but I can't find much. Ill probably toss on some cheap moog ones to see if that cures the problem. FWIW I've taken my truck to the shop 3 separate times and they couldnt pinpoint the issue.
EDIT: Swapped out front endlinks today. Clunk is gone. Although this was probably the sole culprit of my suspension noises, Im very glad I swapped out LCA's, Sway bushings and endlinks. Front end feels so much better.
