Old 01-26-2020, 01:25 AM #1
ad_robotics ad_robotics is offline
ad_robotics is on a distinguished road
Difference between 1st gear (L) and 4L?
Hi, I have a 4th gen 4WD and was wondering about what the difference between the two drive options is?
  • 4H in 1st gear (L)
  • 4L in drive (D)
2005 Limited V6 4WD
ad_robotics is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 01:36 AM #2
sloscheider sloscheider is offline
sloscheider is on a distinguished road
  • 4L in drive (D)
Your transmission has 5 or 6 gears that shift from 1 through 5 as you increase speed - you already know this. These gears are available (not sure about 4th or 5th) in either the 4H or 4L setting.
Changing from 4H to 4L changes between 2 gears in the differential, a High gear which is the normal mode for highway driving and a Low gear which doesn't give you much speed but provides lots of power.
sloscheider is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 02:16 AM #3
Interesting, I wasn't aware that the differential has 2 gears that can be changed. It makes sense now.
Thanks
2005 Limited V6 4WD
Old 01-26-2020, 02:12 PM #4
Back in the 70's Dodge colts and a few others had a 2 gear differential to allow for performance to get going quickly and a high gear for fuel efficiency. I think they called it a "sport" mode. I haven't seen that in a while though
Old 01-26-2020, 02:19 PM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Thanks
The differential does not "change gears". Gear changing/ratio changing is all done in the transfer case or transmission.
Unless you consider the t-case to be a center differential, then I understand. Just know it's not the front or rear differentials.
If I'm doing the math right, 4 high in 1st gear is a little lower ratio than 4th gear in 4 low but I could be wrong.
To me its a weird question to ask. 4 low will turn off some electronic stuff, and I think turn on ATRAC. You can put it in 4 low and 1st gear for really slow hill descents when offroading.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:50 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Transmission has its own set of gear ratios, and so does the t-case… In low range, you can still shift through all 5 transmission gears.
It’s actually somewhat similar to a bicycle that had 2 front and 5 rear gears… you have a total combination of 10 different gear ratios.
What’s cool is you can even increase the amount of gear ratios with a crawl box like the Marlin Taco Box.
Old 01-27-2020, 07:44 PM #7
I really like the bicycle analogy with a front and rear gear combination. I probably misspoke when I said the differential had 2 gears, sorry. Many years ago when I drive a large truck on my sisters farm her husband explained the red switch on the gear shift knob as a split shift differential
Old 08-06-2022, 09:08 PM #8
DAH_2727's Avatar
DAH_2727 DAH_2727 is offline
DAH_2727 is on a distinguished road
DAH_2727's Avatar
Just bought a 4th gen and was running it in 4lo just to check it out. When in 4lo, My shifter doesnt seem to allow me to shift out of “D” and manually select a lower gear like “3” or “L” for example… am I just not being forceful enough with the gear selector? Or is there a procedure for locking the truck in a lower gear range while in 4Lo?
2005 SR5 4x4 T4R - Completely Stock
2020 SR5 Premium 4x4 - Completely stock
DAH_2727 is offline   Reply With QuoteReply With Quote
1st , difference , drive , gear , options
Review: East Coast Gear Supply Gear Swap comtn4x4 5th gen T4Rs 27 09-20-2021 07:57 PM
Difference between 4lo and 4hi in low gear? Stone618 4th Gen T4Rs 22 12-28-2020 02:02 PM
Gear shifter really hard to move/shift into gear (auto trans) infamousRNR 3rd gen T4Rs 7 07-03-2018 03:42 PM
whats the difference with "GL" and "SAE" in gear oil 4Runner_101 3rd gen T4Rs 2 04-16-2014 02:35 AM
difference between lucas 10043 & 10046 80W-90 gear oil ? ycl1688 3rd gen T4Rs 1 07-10-2012 04:30 PM
