Originally Posted by JuniorPigeon
You can use the Baja Designs Squadron R lights with this Ford/Toyota, F-150, Tundra, Tacoma Fog Light Kit and a little modification.
You have to drill a small extra hole in the plastic of your bumper and reverse the polarity going into your factory harness. Very well worth it, I love mine.
Thanks for the link to the mount. Any chance you have a picture of exactly what needs to be drilled and where from when you (I'm assuming) did an install? Or is it pretty apparent once you take the current ones off and try to mount the new lights?
One of my housings has a bad seal, figure I may as well upgrade if I can
