07-19-2021, 11:42 AM
Jaw-dropping repair estimates
Not 3 weeks after buying a 2007 SR5, I have taken it to a mechanic to have some repairs estimated.
This is what they quoted me:
Upper and Lower Control Arms, Shocks/Struts, and alignment: $3,800
Replace rusted trans cooler lines: $1,000
New fuel tank straps: $600
New skid plates: $400 each
Rusted frame repair At least $1,000
I am somewhat mechanically inclined, is it reasonable that I can do any of this myself?
I cannot afford these repairs, unless the dealer does the right thing and makes this right.
07-19-2021, 11:51 AM
Real Name: Ron
Real Name: Ron
If you are somewhat mechanically inclined you can do all of it, except maybe the frame rust repair. I've done all those to my '03 and I'm self-taught mechanic and all of those were done when I was 70 years old (I'm 74 now), except frame rust repair, for which I payed $1000.
07-19-2021, 12:04 PM
The LCA for mine are like 330 each and the UCAs are surely cheaper. There are different ways to get OEM parts but don't get random ebay stuff as it may be fake.
So I would say a lot less than 1,000 for control arms.
A set of decent aftermarket shocks like Bilstein 5100 is under 500.
If spring compressor is an issue, then the parts can be taken to a shop for cheap dis/re-assembly of the struts only, already removed from the vehicle.
New skid plates: at this point, aftermarket skids would be better, why pay for the thin stock ones. If the vehicle does not go offroad, they are not needed.
Fuel tank straps can be nasty but should be doable.
The rusted frame repair and the transmission lines may require more preparation in the form of reading and watching youtube videos. Personally, I would probably rather deal with the frame but I am not sure.
Also, if I get our 2008 Subaru Tribeca to a dealer, they will surely find 1000s worth of repairs. The reality is that all it needs is one hose that I bought OEM for 30$ and that I will replace when the weather improves (November!). It seems normal that you should be replacing control arms (rather than bushings) at this time but it is worth double checking.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
07-19-2021, 12:48 PM
Now I don’t feel so bad getting quotes from my Range Rover dealer! I bought the Toyota to have something new and under warranty.
07-19-2021, 12:53 PM
Very nice my friend! I think I can hold off on some stuff, but the trans cooler lines are a must fix this week.
07-19-2021, 01:54 PM
Thank for your insight. I feel I could definitely do the gas tank straps and save $600. Not feeling good about doing the suspension, but will probably get a second opinion, or, just do control arms first, and then the other stuff. The trans line coolers don't look too bad.
07-19-2021, 04:05 PM
Where in NC you located? I'm in Raleigh, ill help you out.
Sent from my SM-G981V using Tapatalk
06 Curry Runner
07-19-2021, 04:49 PM
Where did this thing live and how many miles to have that much rust damage? Can't imagine it was NC truck all of its life.
Have you inspected the frame rust yourself? Could easily just be surface rust (we all have some)...fix with a little elbow grease and rustoleam. :-) Or rust converter.
Unless something's changed drastically, the factory skids shouldn't be that much each. I replaced the oil pan/engine skid for like $120ish shipped from one of the online Toyota dealers (probably Partznet/Connicelli), albeit probably 6+ years ago.
I haven't done control arms, but did new shocks/struts/springs. Plenty of good DIY write-ups here and T120. While you can pay a shop to do the spring swap for you, I'd recommend going ahead and picking up a kit like this so you'll be prepared to do struts on future vehicles as well. This is pretty much the same design you'll see illustrated as the "special shop tool" in the factory service manual.
None of it's beyond doing in your driveway with basic hand tools. Think of it as a great opportunity to collect new tools.
-Brent
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
07-19-2021, 07:54 PM
Real Name: George
Real Name: George
recommend getting the frame really inspected (even if at dealership) and determine how bad it is. after years of dumping cash into mine (headers, suspension, sound deadening, audio, among much else) its no longer inspect-able in PA due to frame rot.
point is done invest in suspension and all the rest if the truck is in jeopardy.
2005 V8 170k
Doug Thorley Shorties, Magnaflow Cats, Gibson Exhaust
Falken Wildpeak AT3 265/70-17
Gen5 Brake Upgrade
Transmission Fluid Coolant Line Replace
07-19-2021, 10:36 PM
Hello, I’m over in Franklin, NC (west of Asheville)
07-19-2021, 10:40 PM
-Brent
Thanks for your reply and the fact you’re not doom and gloom like some are. It has 141k but it did come out of Ohio. The rust isn’t super terrible but there is one bad spot in the framer under passenger door. Rust converters seem promising, but do they help with rusted holes at all?
I’ve done shocks before on an 88 4Runner and it wasn’t bad. Struts and control arms I have not.
07-19-2021, 10:42 PM
-Brent
I can probably do the skid plates too. The worst part will be getting this rusty bolts off. Probably won’t be using a heat torch near the gas tank tho!
07-19-2021, 10:45 PM
I had a shop look at it today and their main complaint about the rust was the hole in the frame. They quoted about $1,000 or possibly more to fix. I guess they’ll have to weld it. I wanna get a jump start on the other rust to keep it from getting any worse.
07-19-2021, 10:49 PM
Oh mercy LoL
07-19-2021, 11:20 PM
The skid plate bolts will be the issue due to the small(er) diameter than the strap bolts. Mine were extremely rusty, the heads were corroding/falling apart, so I had to come up with ways to dealing with it . . . bolt extractors, drilling, rivnuts, etc . . .and yes, like you noted, the skid bolts are just too close for comfort for the torch.
The strap fasteners are not too close and you can hold up some scrap metal for shielding if you are so inclined. I hit them with the torch then popped them off with the milwaukee 1/2" impact.
Its not a complex or time-consuming job, just follow the write up by
@ y=mx+b
I purchased the liland global straps from RockAuto and I think it was $50 shipped, new pins were $7 from ebay, 8.8 fasteners and washers came out to $8 or so.
Frankly anything on that list is not that difficult. The alignment you could get close but Id pop it on a rack and let the tech figure it out.
