02-27-2022, 08:48 AM
#16
Anyone thinking about converting halogen to LED should read this from Daniel Stern Lighting: Daniel Stern Lighting Consultancy and Supply
Given all the LED junk that is coming from China, even if you get them to play nicely with the systems in the vehicle, they are not the upgrade everyone thinks they are. The article mentioned does a good job of explaining why. Some of the better quality companies are working on a true conversion bulb for halogen but they won't be the $29.95 a pair from China ones. Properly designed, built with quality solid state components and then cycle tested, they will probably be $200-$300 a pair but actually be an improvement with proven longevity. In the meantime, stick with stock no matter the year of your 4R.
02-27-2022, 09:02 AM
#17
A good rule to follow almost always when troubleshooting electrical weirdness is to suspect and check aftermarket parts that have been installed. By a large margin, electrical problems I read about on here occur on modified vehicles. I think remote starts and aftermarket lights are the most common. In my case, an aftermarket remote start took a battery, starter, and alternator with it when it failed. So if you can, electrically remove non-stock items first when troubleshooting.
02-28-2022, 09:37 AM
#18
Real Name: Russell (OB #9908)
Great information. I’ve had LED headlights for years, first Auxbeam high/low beams and have since switched to Boslla B4 Bullets in the lows. LED fogs too. So far, all has been good but I am very happy that this will be in my knowledge base should codes start showing.
02-28-2022, 10:22 PM
#19
Banned
Real Name: Mark
Banned
Real Name: Mark
Thanks for that refresher. If anyone wants LED headlights they should do it properly: install Toyota OEMs. There are several threads here discussing how to make this conversation.
10-22-2022, 09:10 AM
#20
Originally Posted by BrunoKnoxville
ScottD - Can you update us about your fanless LEDs? I've been looking at them, but I'm not sold. How's the heat output? Any issues with the wiring, connectors, or housings?
Still working fine. No heat issues with the Beamtech led bulbs without a fan.
2007 Sport 4x4, Daystar 2.5/1.5, 1.25, Diff drop, Spidertrax, Xreas, Budbuilt/Engo hidden winch, HID Fogs, Rugged Ridge LED Spots, Custom CB, Rola Rack, KDLINKS front/rear dash cam, USB Power, Hula Girl Mod. Build Thread
10-24-2022, 08:26 PM
#21
Same here. Closing in on a year with Beamtech fan-less bulbs and no issues at all. Thought for sure that an Arizona summer might push them to the limit, but still good.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
10-25-2022, 11:38 AM
#22
Another vote for beamtech, I've been running the low beams for almost exactly two years now with no problems
'99 SR5, 2007 Sport
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
