Old 10-24-2022, 01:17 PM #1
COhailtr4 COhailtr4 is offline
COhailtr4 is on a distinguished road
Steering loose on dirt small rocks?
So my 2003 4runner had a factory Toyota steering rack installed in Jan. Drives and steers perfect. I am on 35’s. I just got this truck about a two months ago. Going down a farm field path (pumpkin patch) when I would hit or go over a rock the steering wheel just felt super loose or as if the slighted rock would cause the the steering wheel to have little resistance. I’m not just how to describe, other than I really felt there should have been more pressure holding the steering and not having the steering bounce around so easily. Steering pump doesn’t make any sounds or anything. Truck runs perfect. 220. Is this just normal with 35’s on these guys or?
COhailtr4 is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 02:08 PM #2
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
what's the rest of your suspension look like? I'm assuming to have a new rack in it also got an alignment afterwards? Sounds potentially like not enough caster maybe..
what else was changed during this recent swap out? I can't imagine having anything sloppy or lose in the steering shaft if you're not feeling anything like that on pavement..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 03:40 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
With the truck off and key far enough to unlock the steering wheel, how much side to side play is there turning the wheel? The steering shaft u-joint can make for some odd steering if it's loose.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-24-2022, 06:13 PM #4
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Not enough caster will give you bump steer which makes the steering wheel rotate over a bump. It would also wander on the road if you let go of the steering wheel.
Very common on solid front axle trucks that were not lifted correctly.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 11:43 PM #5
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
Sorry to say but you're going to need to do more work to eliminate that. Here is a list of things I've done to tighten up my steering A LOT from what it used to be. Still a little shaky but far more bearable to drive. I used to stab the gas pedal over bumps and the steering wheel would be out of control. Big heavy tires don't help either
Poly Whiteline LCA bushings
Poly steering rack bushings with 1/2" bolts
Removed rag joint from steering shaft
New tie rod ends
More caster
Next step will be a new steering pump as mine has over 200k miles.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
felt , loose , rock , steering , wheel
Loose steering and wobbly steering wheel even after steering rack bushing replacement psyduck 3rd gen T4Rs 18 07-17-2022 07:17 PM
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
Steering knocking sound on rocks only ohwilliam 3rd gen T4Rs 25 06-02-2015 05:33 PM
Dirt, Mud. Rocks in my airbox seymourwaterz 3rd gen T4Rs 9 01-01-2010 09:40 PM
Here's a small video of my loose seat vin Problems & Warranty Issues 34 05-07-2004 10:25 AM
