Originally Posted by baby#yota
Thanks Seeker, I’ll get plugs tomorrow. Also the truck has 220k on it
Just check the inputs(sensors) related to the ignition/timing, and air fuel ratio systems after looking at the plugs and injectors. Any of these inputs can trigger a misfire code. Crank position, cam position, maf, iac. Usually it's as simple a cleaning the sensors. Crud and metal particles can throw the sensors off causing intermittent issues. Make sure it's not bad first obviously with multimeter. At 100000 miles I cleaned all these sensors and throttle body all at the same time and relearned the truck afterwards to tell the computer the sensors are clean and not to run like shit anymore. Huge difference in performance and gas mileage. You need to do this maintenance anyways and you'll find the issue.
