Old 02-03-2020, 09:05 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
My tail pipe just severed in half??
Yea im out of ideas at this point anyone got anything better? I was thinking chop the rusted/corroded ends off and fit a steel pipe around both ends and secure with exhaust clamps?
BigMike18 is offline   Reply With QuoteReply With Quote
Old 02-03-2020, 09:06 PM #2
Forgot the picture my bad....
My tail pipe just severed in half??-60246964177__1d5c6725-bdc6-4b4b-bf81-46bc6fe39962-jpg
Old 02-03-2020, 10:17 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I had that happen up north with a lot of salt and corrosion
I did an internal pipe fitting and then used exhaust clamps on the outside.
Mine was more of a temporary fix to get it through state inspection. Eventually the frame rusted through.
Good luck with repair.
Old 02-03-2020, 10:57 PM #4
what do you mean internal pipe fitting?
Old 02-04-2020, 12:40 PM #5
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
Maybe stick a pipe inside with the same outside diameter as the insider diameter of the exhaust and clamp it down....
"Rust never sleeps."
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 06:43 PM #6
Would putting a slightly bigger diameter over it and then clamping as well as exhaust “tape” or the film you heat gun on to not possibly leak and have a more firm connection
Old 02-04-2020, 06:53 PM #7
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Exhaust clamp might work. It looks straight
radlynx is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 06:56 PM #8
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Get a Walker cat-back and tail pipe. It was less than $300 in 2017 for a V8 and fits perfect, goes on in half an hour.
rdruss is online now   Reply With QuoteReply With Quote
Old 02-04-2020, 09:05 PM #9
Wish I could do that but previous guy welded this part together so I would have to replace almost the entire exhaust
My tail pipe just severed in half??-71dc974e-a3fd-4377-bdf5-61267079a557-jpg
Old 02-05-2020, 12:04 AM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
Sadly, almost anything you do will not last without replacing the pipes. If you are looking to get through the winter then measure the ID of both pipes then go to your local auto parts store and get a 3" long pipe with the same OD of what you measured. Stick it in each pipe and put a pipe clamp on each pipe over where the 3" piece is. That should last awhile and should be less than a $20 to do.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 02-11-2020, 11:53 PM #11
Registered User
Registered User
Any status
Old 02-12-2020, 01:30 AM #12
Originally Posted by radlynx View Post
Any status
Was going to go with temp fix with a small extension pipe but opted for replacing muffler, tailpipe, and 2nd rear cat for around $340
Old 02-12-2020, 10:35 AM #13
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
I would not go with any quick half way fix's with your exhaust system, if it leaks into your 4Runner it might not have a good ending.
You need it fixed right.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 11:16 AM #14
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
are you referencing death?
hinmo24t is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 06:57 PM #15
MikeinNH67's Avatar
MikeinNH67's Avatar
Sounds like a good price for what you got.
Mike
03 4runner Limited
chop , ends , fit , pipe , rusted/corroded
Need a muffler and tail pipe, what to buy... thegipper 3rd gen T4Rs 38 02-05-2020 10:31 PM
Best looking tail pipe? KurtL 3rd gen T4Rs 29 08-18-2012 01:42 PM
H20 from tail pipe??? akdawg Classic T4Rs 5 09-16-2010 10:53 PM
Tail Pipe Extender andyboy 4th Gen T4Rs 4 09-07-2009 11:53 AM
Tail pipe tip Satman 4th Gen T4Rs 11 07-03-2004 06:29 PM
