Old 03-07-2020, 03:17 AM #31
Jeremy_A's Avatar
Jeremy_A Jeremy_A is offline
Real Name: Jeremy
Jeremy_A has a spectacular aura about Jeremy_A has a spectacular aura about
Jeremy_A's Avatar
Real Name: Jeremy
Your local? You follow Vegas 4runners on FB? Im.a admin.
Anyways mine is pretty smooth.... I dont find the roads to be too bad... I lived in TN/KY before though.
2007 4Runner Sport 4x4
CoastalOffroad-Smittybilt-4xInnovation-RCI-BajaRack-SPC-ICON-Nitro4.88-EatonElocker-CVJ--PolyPerformance-Method-MickeyThompson⁹-AFE-Urd-Gibson-SprintBooster-Weathertech-Pioneer-Infinity-DiodeDynamics-OPT7-HiLift-Coverking
Build thread:
https://www.toyota-4runner.org/4th-g...ort-build.html
Jeremy_A is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 04:28 PM #32
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Originally Posted by SolRayz View Post
Thanks everyone for the responses. I will probably look into getting CVJ axles and Bluepitbearings. This may have to wait a bit, but I will update with my findings once its all said and done.
If there is any possible way I can convince you to get Toyota Koyo bearings from the actual Toyota dealer instead of online I will. Literally 95% of all bearings labelled Koyo sold anywhere on any website are fakes and there is no way for anyone to know except Koyo. ( I used to work for the company who owns Koyo and it is still a massive problem 10 years later )
For my own truck, I just get multiples of the cheapest bearings I can knowing that they are all the same and they are all fake if they aren't from one of the authorized dealers in the USA. If you got a "deal" on a Koyo bearing, you did not get a Koyo bearing.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 06:01 PM #33
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
^ This
I just went through the hassle of replacing "Koyo" wheel hub assemblies bought off eBay, they were even assembled by a Toyota tech, or so the listing said.
I posted some info about my experience in my build thread on post 34 here and Post 37 here.
Unless you like replacing them every 10-20k...
@duffdog you must be the one I was referencing in post 34... I remember reading a thread someone posted in having worked for them before... I wish I could find that thread again.
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 06:19 PM #34
SolRayz's Avatar
SolRayz SolRayz is offline
SolRayz is on a distinguished road
SolRayz's Avatar
So just wanted to update, since it's been awhile.
Ended up replacing both UCA's (passenger side upper ball joint blown out), and front wheel bearings with bluepitt Koyo bearings (even though original stock were fine, keep as spares), and also replaced passenger CV axle that was showing some boot separation. Some improvement after UCA's were replaced. However, steering wheel shimmy and subtle vibrations after 65mph remained.
I ended up going back to Firestone and had them swap out the Destination AT2's for Bridgestone Revo 3's under warranty.
I'm happy to report, problem solved.
Shimmy and vibrations are GONE.
Firestone said it was probably only one of the tires that was bad. I call bs, because all four tires were rotated in every which way, rebalanced a half a dozen times and also Road Force balanced, and they would lose balance after a few days driving and start shimmying like crazy again. So either, I was unlucky to have had a bad batch of Destinations installed, or they simply don't balance probably and ride like garbage. Either way, I would suggest avoiding those tires at all cost. I'm finding that the Revo's far out class the Destinations when it comes to absorbing uneven and poor road conditions, so the ride is orders of magnitude smoother in general.
It was a long battle, but I learned a lot about rebuilding the front end and never discount the fact that your tires might be the source of your vibration woes.
-----Marc-----
2003 V8 Limited 4WD
SolRayz is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 02:03 AM #35
SolRayz's Avatar
SolRayz's Avatar
Ok so the damn problem is back. Steering wheel shimmy between 65-70 and floorboard harmonic vibration (rmmm rmmm rmmm) while accelerating, especially at 65-70 mph.
Not sure if these items are related to each other.
Its either this...
ST001R-05 09/08/2005 Steering - Highway Speed Steering 'Flutter'
and maybe this...
Slip Yoke caused my vibration....
and/or this...
Harmonic Vibration @ 70 to 75mph?
I don't know anymore. I do know this, the steering flutter was good for several weeks after the new tires, but the floorboard harmonic vibration was always there. Now I'm back to both issues. Driving me nuts.
-----Marc-----
2003 V8 Limited 4WD
Old 11-06-2020, 02:11 PM #36
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
How frequently do you grease the zerks on your front (and rear) driveshaft, and what grease do you use? Same for the slip joint and u-joints?
Its either this...
and maybe this...
and/or this...
waypoint is offline   Reply With QuoteReply With Quote
driver , movement , ongoing , passenger , side
Any welding experts out there? Opinion needed elysiancomrade01 3rd gen T4Rs 22 09-18-2018 07:47 PM
How bad did I screw up...... Frame experts needed Fezzik 3rd gen T4Rs 23 07-04-2017 06:20 PM
CB Radio Experts needed! cpark_12 Off Topic 0 06-17-2016 01:26 PM
Suspension Experts Needed dr3ww3rd 5th gen T4Rs 27 12-01-2015 11:42 PM
13WL Experts Needed Yoter 3rd gen T4Rs 5 01-05-2014 10:38 AM
