Old 02-04-2020, 06:41 PM #1
SolRayz's Avatar
SolRayz SolRayz is offline
SolRayz is on a distinguished road
SolRayz's Avatar
CV Axle Experts needed (VIDEO)
In my ongoing attempt to solve driveline vibrations, I'm down to CV's. Can anyone verify whether the slop/wobble on the driver side CV is normal? Passenger side seems tight. Also if I reach in and push up and down on the driver side inner CV there some up and down movement, not terrible, maybe less than a 1/16 inch. Passenger side no movement. Rattling sound in the videos is my skidplate.
Driver Side
Passenger Side
-----Marc-----
2003 V8 Limited 4WD
SolRayz is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 07:35 PM #2
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I don't think it's the CV.
radlynx is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 07:36 PM #3
Registered User
Registered User
I can see the bottom cover vibrating.
Old 02-04-2020, 07:37 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I don't see any issues with either side.
What kind of vibration are you feeling?
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 07:59 PM #5
SolRayz's Avatar
SolRayz's Avatar
I have the infamous harmonic rhom rhom rhom vibration between 70-75mph (around 2100rpm) while accelerating. I can feel vibrations in the gas pedal and on the floorboard beneath my left foot only. There are no abnormal noises when accel, stopping, or turning. Its only vibrations at highway speed.
The wheel bearings seem fine, no play or noise. U-joints on the driveshaft maybe? The slight driver side CV wobble possibly?
I've replaced left and right front and rear suspension
Both LCA's
Both Inner and Outer Tie Rods
Swaybar endlinks and bushings
4x firestone Destination AT/2 Tires
Balanced and rotated twice, last being at Toyota
Alignment at Toyota.
Both Diffs, Trans, and Transmission drain and filled within the last month
Truck drives smooth otherwise. I've been researching this for a month, and throughout the forums, nothing has been conclusive on this harmonic accel vibration.
-----Marc-----
2003 V8 Limited 4WD
Old 02-04-2020, 08:24 PM #6
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Ive heard some people have a sound from the front diff that goes away in 4wd. They end up replacing some bearing with a sleeve. Forgot what it was/called. Some 5th gens have the problem too.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 08:34 PM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Both LCA's
I question the tires.
Old 02-04-2020, 08:37 PM #8
SolRayz's Avatar
SolRayz's Avatar
Not the tires. This was happening on my old Toyo AT's. These Firestone's are brand new.
-----Marc-----
2003 V8 Limited 4WD
Old 02-04-2020, 10:20 PM #9
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Front driveshaft then. Check the ujoints and slip joint for play. If none, grease the shit outta them.
Old 02-04-2020, 10:44 PM #10
montijo505's Avatar
montijo505's Avatar
The bearing in the diff mentioned above is the needle bearing in the front diff. ECGS sells the bearing and tool. Easy job. Plenty of write ups on how to do it.
Old 02-04-2020, 11:48 PM #11
SolRayz's Avatar
SolRayz's Avatar
I'll be crawling under and checking those next weekend.
-----Marc-----
2003 V8 Limited 4WD
Old 02-04-2020, 11:53 PM #12
SolRayz's Avatar
SolRayz's Avatar
If you're talking about
TOYOTA 8" CLAMSHELL CV AXLE BUSHING
this is for non AWD models which counts me out.
-----Marc-----
2003 V8 Limited 4WD
Old 02-05-2020, 10:56 AM #13
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Have you ever tried different rims? Like a whole different set of tires and rims? Just to see if there is any difference?
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 12:26 PM #14
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
subd. I think I have the same issue happening
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 07:42 PM #15
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
It's probably a wheel bearing. They can look perfectly fine on the outside but still be slowly self destructing on the inside. For what it's worth, same exact symptoms that I had a few years ago. Replaced both bearings and everything went back to normal.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
driver , movement , ongoing , passenger , side
Any welding experts out there? Opinion needed elysiancomrade01 3rd gen T4Rs 22 09-18-2018 07:47 PM
How bad did I screw up...... Frame experts needed Fezzik 3rd gen T4Rs 23 07-04-2017 06:20 PM
CB Radio Experts needed! cpark_12 Off Topic 0 06-17-2016 01:26 PM
Suspension Experts Needed dr3ww3rd 5th gen T4Rs 27 12-01-2015 11:42 PM
13WL Experts Needed Yoter 3rd gen T4Rs 5 01-05-2014 10:38 AM
