Old 02-05-2020, 08:45 PM #16
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Originally Posted by Drunner97 View Post
It's probably a wheel bearing. They can look perfectly fine on the outside but still be slowly self destructing on the inside. For what it's worth, same exact symptoms that I had a few years ago. Replaced both bearings and everything went back to normal.
Man, I just replaced them in June... if that's the case I'm gonna be pissed for buying those timken "assembled by a Toyota tech" bearings off eBay.
How's the saying go, "If it's too good to be true........"
I have a sneaking suspicion your right tho.
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 08:57 PM #17
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
If you're really lucky, it's a loose bolt somewhere on the assembly, although I'd expect you to have vibrations across more speed ranges if that was the case. The 70-75, gas pedal and steering wheel leads me to believe bearing. Could still definitely be something else though.
Sent from my Pixel 2 using Tapatalk
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 05:05 PM #18
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
I could have sworn it was in time with the skid plate. That thing was shaking and I dont think it should, kind of soundd like it also. Skid plate bolts strip out easy, have you checked them ?????
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 08:03 PM #19
SolRayz's Avatar
SolRayz SolRayz is offline
SolRayz is on a distinguished road
SolRayz's Avatar
I re-tapped and replaced my skid plate bolts last night so that rattling sound is a thing of the past. I assure you the vibe is not skid plate.
Also got under and lubed all the zerks, not much difference quite frankly.
Quick question on wheel bearings in these 4runners.
How quiet and frictionless should these hubs turn. When I rotate them by hand, I certainly hear them turn. No grinding or anything, but not quiet either.
-----Marc-----
2003 V8 Limited 4WD
SolRayz is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 09:56 PM #20
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
I honestly think it's your cv's, I have had birfields go in my 87 runner and it sounded just like this. I would pull them and see how much play is in them.
Are the cv's old?, sounds to me like they are low on grease and have excessive play.
Ida4runner is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:00 PM #21
watching the video again I would take the skid plate off and take it for a ride,looks like it's lose and vibrating against your frame.
Old 02-06-2020, 11:44 PM #22
SolRayz's Avatar
SolRayz's Avatar
CV's are original, so about 202,000 miles. Is that old?
-----Marc-----
2003 V8 Limited 4WD
Old 02-07-2020, 12:02 AM #23
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Boots look ok? No rips? 202k is quite a bit...they maight have some play or are low on grease as stated above.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 09:56 AM #24
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
202k doesn't necessarily mean they're bad, but they could possibly be causing it. IMO its 50/50 on those. You could swap cv sides and see if anything changes? Or just buy one new one and put it in to driver side to see if that fixes it.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 11:12 AM #25
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
If the axles were bad, you'd know it, and they don't typically go unless you lose the grease in them. When I pulled my wheel bearings you could hear the difference between the new one and the old one. The new ones really shouldn't make any noise at all when you spin them.
IG: @4runner_doa
Old 02-08-2020, 01:21 AM #26
SolRayz's Avatar
SolRayz's Avatar
Thanks everyone for the responses. I will probably look into getting CVJ axles and Bluepitbearings. This may have to wait a bit, but I will update with my findings once its all said and done.
-----Marc-----
2003 V8 Limited 4WD
Old 02-08-2020, 09:15 AM #27
Is it just me or does anyone else think the left front tire tread is shifting back and fourth in the top video ???
It also looks maybe like it's out of round, watch at 2:14 seconds.
Old 03-06-2020, 11:12 PM #28
SolRayz's Avatar
SolRayz's Avatar
Yup, I also noticed exactly what you described. And looking at the video on the passenger side is smooth, no wobble in the tire whatsoever. I decided to swap rear and front driver side tires and record another video. I don't see much tread shifting with this wheel.
The tires have been balanced twice now, last being at Toyota. My suspicion is that I may have damaged the wheel off road about a year ago. Hit some pretty hard ruts and drove it a little too hard on some trails north of Vegas for over 45 miles. I feel I might of thrown the wheel out of round.
That being said, the ride seems smoother now with that wheel on the rear. Here is a short clip from my GoPro.
-----Marc-----
2003 V8 Limited 4WD
Old 03-06-2020, 11:35 PM #29
Jeremy_A's Avatar
Jeremy_A Jeremy_A is offline
Real Name: Jeremy
Jeremy_A has a spectacular aura about Jeremy_A has a spectacular aura about
Jeremy_A's Avatar
Real Name: Jeremy
Vegas? I live in vegas. What tires are these?
2007 4Runner Sport 4x4
CoastalOffroad-Smittybilt-4xInnovation-RCI-BajaRack-SPC-ICON-Nitro4.88-EatonElocker-CVJ--PolyPerformance-Method-MickeyThompson⁹-AFE-Urd-Gibson-SprintBooster-Weathertech-Pioneer-Infinity-DiodeDynamics-OPT7-HiLift-Coverking
Build thread:
https://www.toyota-4runner.org/4th-g...ort-build.html
Jeremy_A is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 01:02 AM #30
SolRayz's Avatar
SolRayz's Avatar
Firestone Destination AT2. So far so good with these.
Quick question, what is your opinion of the roads here in Vegas? I personally find them real bad, to the point where I can't tell if theirs something wrong with my truck or its the roads vibrating me to death. The 15 and 215 are utter shit, the side roads are utter shit. Seriously wtf. In places it seems like theirs a waviness to the road, almost like your tires are out of balance, but they're not. For me it always happens in the same areas on my commute home.
It seems like you've done quite a bit of modifications on your Runner, but how is your ride quality on these roads?
-----Marc-----
2003 V8 Limited 4WD
driver , movement , ongoing , passenger , side
Any welding experts out there? Opinion needed elysiancomrade01 3rd gen T4Rs 22 09-18-2018 07:47 PM
How bad did I screw up...... Frame experts needed Fezzik 3rd gen T4Rs 23 07-04-2017 06:20 PM
CB Radio Experts needed! cpark_12 Off Topic 0 06-17-2016 01:26 PM
Suspension Experts Needed dr3ww3rd 5th gen T4Rs 27 12-01-2015 11:42 PM
13WL Experts Needed Yoter 3rd gen T4Rs 5 01-05-2014 10:38 AM
