02-01-2020, 03:47 PM
Real Name: Mikey Barger
Spark plug bolts rusted/stripped
Alright so trying to replace my plugs and can’t even get the bolts to turn even though my ratchet is turning, WD-40 and no luck. Any ideas on how to get these things out? I don’t think my propane torch is a good idea.
02-01-2020, 05:16 PM
just asking, but is the socket the right size & is fully seated on the plug? a true spark plug socket has a rubber insert to grab the plug & sometimes it takes some force to push it all the way on.
if it is on there right, the plug nut could be rounded letting the socket slip.
02-01-2020, 06:42 PM
This is what I mean
02-01-2020, 06:50 PM
Real Name: Carlos V.
The "coil" bolt.
Originally Posted by BigMike18
This is what I mean
The "coil" bolt.
Glad U ask. Let see what the experts recommend.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
02-01-2020, 07:36 PM
Registered User
Registered User
You can vice grips it.
02-01-2020, 09:18 PM
Get some penetrating oil, soak overnight. Usually works well for me.
2007 SR5 4.0 V6 210k
02-01-2020, 10:00 PM
Like MTN_man said, use penetrating oil (PB Blaster or Kroil). WD-40 does absolutely nothing on seized bolts. Then hammer on a 3/8" socket or maybe a 9mm if it's really rounded. If all else fails, you'll need to get a bolt extractor. Home Depot or Lowes usually has them in stock:
https://www.lowes.com/pd/IRWIN-BOLT-...Set/1000363541
02-02-2020, 12:35 AM
First of all, make sure all the surface rust is removed from the head of the bolt. If I remember correctly, that bolt is a 10mm metric. Be sure to use a 6 point socket (a 12 point might not grab if the bolt head has been reduced in size from surface rust). I would use a 3/8" drive socket with a breaker bar (instead of a ratchet wrench) and a 3" extension to control how you apply slow steady pressure when trying to break the bolt loose. If the 6 point 10mm socket still slips on the bolt head, then you have to go to a smaller size socket. I would next try a 3/8" (sae) 6 point socket. The 3/8ths sae socket is slightly smaller than the 10mm, and might work. If the 3/8ths socket fits, but not all the way on th bolt head, you can try lightly tapping the socket to seat it better on the bolt head. If the 3/8ths socket is still too large, then maybe try a 9mm next.
I would not use any heat (ie torch) on the bolt, you might ruin the coil the bolt is holding in place.
Another option, if you can get a 6 point socket that will fit snugly on the bolt head, is to use an old fashioned hammer driven impact driver (not an air gun). Many times the hammer impact along with the twisting action of the impact driver will break a stubborn bolt loose.
Remember you have a steel threaded bolt in a threaded hole in an aluminum head. There is bound to be some corrosion between the two types of metal.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
02-02-2020, 09:07 AM
Follow above advice: penetrating oil, clean surface rust, etc.
Then go drive your truck 15 minutes, and try with the engine warm.
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
02-02-2020, 09:22 AM
Real Name: Todd
Real Name: Todd
This. And use anti-seize when you finally put it back together.
02-02-2020, 10:11 AM
Real Name: Skip
Real Name: Skip
Also be careful not to break the bolt/s by applying to much force, those bolts are not all that big and will snap easily, then you'll be force to drill out the bolt(which is not easy drilling a steel bolt in aluminum without drifting off the broken bolt) and possibly have to drill and retap the hole to the next bigger size or install a Helicoil.
2004 Limited V8
02-04-2020, 02:44 PM
I used to work on motorcycles, they are famous for steel screws galling in the aluminum motor cases.
I purchased an impact driver. This is a mechanical tool that you hit with a hammer to turn a loosen screws or bolts.
If the rust buster doesn’t work this will.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
02-04-2020, 03:11 PM
Real Name: Michael
Real Name: Michael
I think this goes without saying, but make sure you replace with new hardware when done. I had the same situation with mine when I did plugs. Had to hammer on a smaller socket
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
02-04-2020, 03:43 PM
Yep, what I said.
02-04-2020, 04:28 PM
Penetrating oil, soak over night and than just go slow and easy. Loosen and tighten, back and forth. Can take up to 15min, but will not damage the thread. Good luck!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
