Old 02-05-2020, 05:33 PM #1
Crikeymike's Avatar
Crikeymike Crikeymike is online now
Crikeymike is a glorious beacon of light Crikeymike is a glorious beacon of light Crikeymike is a glorious beacon of light Crikeymike is a glorious beacon of light Crikeymike is a glorious beacon of light
Crikeymike's Avatar
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners
The cat got out of the bag recently about the new Dobinsons IMS shocks, so I'm starting this thread to give the details about these new struts and shocks from Dobinsons that are arriving in March 2020, and some versions coming after (long travel, no ETA yet, but probably some time in June 2020).
IMS
Internal reservoir
Monotube
Shocks
I guess IRMS sounded silly, and considering the already existing MRR (Monotube Remote Resi), a non-resi version didn't sound right either, this is the wording Dobinsons are going with.
In a nutshell, the IMS struts and shocks are almost the same as the MRR/MRA but with an IFP (Internal Floating Piston) inside the shock body with a small gas reservoir, and no external hose or reservoir. Same monotube body size, piston diameter, shaft thickness, and also the struts are height adjustable thanks to the fully threaded body. Super easy installation.
These do not have any valving adjustment.
From the manufacturer:
Dobinsons IMS Monotube Shock Absorbers are designed for next level performance over Twin Tube Shocks in those hot, harsh, demanding conditions. By utilising the Monotube design, Dobinsons IMS Shock Absorbers are able to resist fade far longer on corrugated roads, long or hard working 4WD trips, towing or racing conditions.
The larger 50 and 60mm high flow pistons reduce internal pressures, reduce the heat generated, transfer heat to the body for faster cooling and offer improved damping performance and vehicle control at higher shaft speeds on rough terrain and during big impacts. Threaded bodies on struts allow for fine tuning of height and offer further improvements in cooling.
The micro-polished, hard chromed and heat treated shock shaft, CNC aluminium high flow race inspired piston, and DOM seamless tubing body provides the ultimate in performance and off-road durability.
Composite piston wear bands and a race style 3-stage sealing system offer the lowest levels of friction whilst maintaining durability and longevity. Dobinsons team of engineers spend hundreds of hours of testing and tuning
the shim stacks and damping characteristics in each IMS Shock to ensure a balance of comfort, handling, vehicle control and offroad performance - Enjoy the ride
Features
  • Fully re-buildable and re-valvable
  • No set rebuild time period
  • Zero shock fade in all terrains with full load
  • Direct, bolt-on replacement for easy fitment
  • Uses existing full range of coil springs and top mounts
  • Highest quality rubber bushings top and bottom for maximum NVH dampening
  • Corrosion resistant (EDP Surface Protection)
  • Heavy duty single piece lower leg
  • Enormous oil capacity
  • Heavy Duty 3 Stage FKM HNBR Sealing System for the ultimate in reliability
  • Race inspired hi-flow CNC 6061 Billet alloy piston – for the ultimate in offroad handling
  • 56mm/2.2” Bodied Series - 50mm hi-flow CNC 6061 Billet alloy piston - 50mm bore
  • 66mm/2.6” Bodied Series - 60mm hi-flow CNC 6061 Billet alloy piston - 60mm bore
The body size is 56mm with a 50mm piston for these vehicles:
4th/5th Gen 4Runner
2nd/3rd Gen Tacoma
Lexus GX470 and GX460
The body size is 66mm with a 60mm piston for these vehicles:
Land Cruiser 80, 100, and 200 series
Part numbers for 4th Gen IMS struts and shocks. Click on part number to see pricing and further details of each item. **SOLD IN PAIRS**
IMS59-50220 - IMS Front Long Travel Struts - suits 0-3.5" lift - stock arrived
IMS59-50705 - IMS Rear Shocks comfort valved - suits 0-3" lift - stock arrived
IMS59-50701 - IMS Rear Shocks medium/heavy valved - suits 0-3" lift - stock arrived 2/25/20 (uses these for a vehicle with constant rear weight)
IMS59-50575 - IMS Rear Long Travel Shocks - suits 3"+ lift (not for KDSS models) due May/June 2020
Initial pricing is $500/pr front struts and $450/pr rear shocks.
Edit: adding some installation info:
Setting coil seat height
The IMS59-50220 come with a full threaded body, and the coil seat height needs to be set prior to installing the coils onto them. A proper strut coil compressor is required. Regular rental compressors can have teeth that hold the coil which are too thick, they won't work, as you probably won't be able to get the teeth out once the coil is on the strut. We offer the assembly of the front coilovers with new top mounts for an extra charge.
2 base options:
213mm - Base setting, same as OE, for coil seat height. Use this with lifted coil springs to let the coils do the lifting only
226mm - Taller setting, adds 1" of lift to whatever coil springs you're using. Use this setting with a 2" coil to produce 3" of lift, for example.
  • Spin both collars down on the strut almost to the bottom. Never use any locktight, it will gum up the threads and it's not necessary once you see the step below.
  • Slide the coil seat onto the strut, with the flattest side facing down (notch facing upwards for coil to sit against)
  • Using a tape measure, hold the tape against the lip/notch of the coil seat (where the pigtail of the coil will sit) and measure down to center of the lower mounting hole. Raise or lower the top adjuster collar until the coil seat is in the correct position.
  • Once the height is set, take both adjuster tools that were supplied. Hold the top adjuster in place, and bring the 2nd adjuster up to the top one, and lock them together. This is the same as "double nutting". This is insurance to keep the top adjuster in position and keep the height where it is.
  • If ever you need to adjust the coilover up or down, ALWAYS undo the lower adjuster FIRST, slide it down out of the way, then adjust the upper adjuster to the correct position. If you try to move both adjusters at once, the threads will most likely get damaged and you won't be happy.
  • I'll be making a video and posting it up when I get a chance, as it's a pretty simple process, but worth getting a visual for too.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-dobinsons-ims-description-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-dobinsons-ims-spec-sheet-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-dobinsons-ims-4runner-kit-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-dobinsons-ims-4runner-kit-all-black-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-ims-kit-red-jpg
Exit Offroad - Specialist of Dobinsons Suspension & Accessories - PM me for T4R Discount Code
www.exitoffroad.com | Facebook Group | Youtube Channel | Email
Crikeymike, Aussiemike, Dobinsons Mike, ARB Mike - I go by many names!!
Been in the offroad industry since 1998. Born & raised in Australia - currently in Miami. 2014 4runner Trail, 3/2" Dobinsons Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, CBI skids
Crikeymike is online now   Reply With QuoteReply With Quote
Old 02-05-2020, 05:42 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about
xtremewlr's Avatar
Real Name: Todd
Would you stop it already?!? I'm broke as it is, now I want to be more broke!
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 05:50 PM #3
Crikeymike's Avatar
Crikeymike's Avatar
Should have bought Tesla shares last Friday and sold on Tuesday.... hahah. Wish I'd done that too
Old 02-11-2020, 10:35 PM #4
Az4runnin's Avatar
Az4runnin Az4runnin is online now
Az4runnin will become famous soon enough
Az4runnin's Avatar
Thumbs up
This looks like a Very Nice set up at a very Fair Price.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 BFG KO2 275-70-17 E, Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is online now   Reply With QuoteReply With Quote
Old 02-12-2020, 08:48 AM #5
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 is on a distinguished road
Real Name: Newell
How does the adjustability work with a fully threaded body?
Since there appear to be no pre-set height positions, would that make it difficult to set the fronts at the same height?
Or was the thought that you could level out any right-left lean?
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 09:30 AM #6
Crikeymike's Avatar
Crikeymike's Avatar
You would set them to the height appropriate to how much lift you want, based on the measurement from the bottom lip of the coil seat to the center of the lower mounting hole.
213mm for stock coil seat height. Use the coils to gain the lift.
226mm for adding 1" of lift to whatever 2" coils are used, combination of taller coil seat and lifted coils to gain 3" of height.
And yes, you can balance left to right easily, removing height from the high side is the easiest way.
Counting a full rotation of the collar is the easiest way to track how much you've lowered or raised it.
Old 02-12-2020, 10:03 AM #7
Crikeymike's Avatar
Crikeymike's Avatar
Just adding this to the first post, but adding it here to that everyone will see it that's interested.
2 base options:
Old 02-12-2020, 11:16 AM #8
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
Wow. I wish these had been available when I ordered my regular Dobinsons setup in 2018. They look great and the price is nice. If they perform as well (for their class of shock) as the regular shocks do I think they will be a winner and a nice step between a regular lift and a fully blown 2.5" setup with resi's both in terms of cost and performance.
If I weren't completely happy with my current Dobby setup I'd be ordering these.
Looking forward to some real world reviews.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 04:46 PM #9
Crikeymike's Avatar
Crikeymike's Avatar
Here's an ETA update.
The IMS59-50701 rear shocks have just arrived.
Waiting for the front struts and the rear comfort options to arrive about the 3rd week of March. Still no ETA on the long travel rears, hopefully May/June arrival.
Old 02-27-2020, 05:50 PM #10
Crikeymike's Avatar
Crikeymike's Avatar
Front 5th Gen Dobinsons IMS struts getting assembled and shipped out yesterday. The 4th Gen struts will look identical.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-ims-assembly-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 4th Gen 4Runners-ims-assembly-b-jpg
Old 02-28-2020, 04:46 PM #11
gimlithepirate gimlithepirate is offline
gimlithepirate is on a distinguished road
2 base options:
Forgive the stupid question, but are these adjustable once the spring is on? Or do you have to use a spring compressor every time you want to adjust the height of the coilover?
Either way, this looks like a great option for the 4runner!
2007 v8 4Runner Limited: RSG Rocksliders, Eibach Pro-Truck Lift, Falken AT3W 255/80r17, FJ Cruiser Wheels, Window Up Mod, Off Roading Gear Awning, Inclinometer, and Cali Raised USB Charger.
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 04:50 PM #12
Crikeymike's Avatar
Crikeymike's Avatar
Mild adjustments can be done on the car, but it's best to remove them and compress the spring to adjust them. If there is grit or dirt in the threads, the adjuster rings could get jammed and that would be pretty bad.
Old 03-01-2020, 01:24 PM #13
OC2003's Avatar
OC2003 OC2003 is offline
OC2003 is on a distinguished road
OC2003's Avatar
I am curious as to travel gains I can expect using this setup on my 04 4runner and what springs you would recommend for 3" of lift with about 100# extra weight.
Thanks
[SIGPIC[/SIGPIC]03 V8 limited
Front 5100 toytec 620# springs jba uca
Rear 5160 with sway away springs. Rci skid. Spc rear trailing arms
Diff drop 285/70/17 k02 n 17x9 ar172
OC2003 is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 03:01 PM #14
Crikeymike's Avatar
Crikeymike's Avatar
Thanks
Over stock or over 5100s? Long travel fronts give about 2" extra wheel travel than stock. For the rear, depends if you go with the standard or the long travel. From memory, it's about 3" and then 6" over stock.
352 front coils for the front and 677V rear coils for 3" front and back
Old 03-01-2020, 04:05 PM #15
OC2003's Avatar
OC2003's Avatar
Over 5100. Mine are wearing out and it's time to make an upgrade and these look like a good route to take. Are the long travel fronts available now? Where can I order them?
body , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 36 05-28-2020 08:33 PM
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners Crikeymike 5th gen T4Rs 41 05-25-2020 07:28 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 19 04-30-2020 09:21 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
New Height Adjustable Full Lift Kit for 4th and 5th gen 4Runners! ToyTec Lifts Toytec Lifts 2 10-08-2012 09:29 PM
