Old 02-05-2020, 08:27 PM #1
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Terrible ride rear suspension.
Have a 05 V8 4WD with 245k
I’m an environmental consultant, I beat my truck to death, constant rough gravel roads littered with huge pot holes. The ride is spine breaking jarring....
I’m running 5100s, and Michelin’s.
Front I’ve replaced LCA/UCA bushings and ball joints, sway bar, tie rods etc.
The front end is tight as it should be.
When I hit bumps the front takes them well, but the rear just hops and shakes all over the place. I’m thinking the bushing in the rear suspension arms are shot, but they look okay upon inspection.
Also thinking about replacing the body mounts, they have been beat, but I can’t find anything about those who have done this.
Just trying to figure out where to begin...
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 08:56 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
If the rear is hopping, then make sure the rear shocks aren't shot.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 09:03 PM #3
codeman528 codeman528 is offline
codeman528 is on a distinguished road
Definitely check out the shocks to make sure they aren't leaking. Also you may be on to something with the arms! All four of my rear arm's bushings were shot or on their way out; the ride was not bouncy because I had new shocks, but boy was the rear end harsh going over bumps. New arms with fresh rubber made a HUGE difference.
2005 V8 Sport Edition 4WD | Bilstein 5100 | OME 885 and 895 | TRD Pro Wheels | 265/70/17 Falken Wildpeak AT3s | USA Spec Bluetooth Audio | Rago Fabrication Molle Panel | Victory 4x4 Front and Rear Bumpers | BajaDesigns Squadron Sport Ditch Lights | Morimoto HID Retrofit
codeman528 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:48 AM #4
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
You're on the right track with the bushings. With your miles and type of driving conditions, even though they look ok, they will be worn out.
New body mounts will definitely help reduce the harshness and vibration that's transmitted to the body too. What tire pressure are you running?
Since your doing plenty of offroad work, I also recommend upgrading tthe shocks and coils to a properly matched set.
techno is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:51 AM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
New body mount bushings are expensive. Around $500.
4th Gen Poly-Urethane Body Mounts
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 12:02 PM #6
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Sounds like shocks to me: I'd suggest, based on your driving, going for a shock that's designed to absorb the heat from the higher speed driving on gravel.
A reservoir shock would probably be best albeit $$$
Choosing the Right Shock Absorbers for Your Truck | 4WD.com
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 12:23 PM #7
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I was bottoming out with stock suspension in the rear. I added a 2.5 inch spacer in the rear and now it rides much better. The long term goal is proper suspension but the rear coil lift helped immensely.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 06:47 PM #8
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Great suggestion, as well as all others above.
I was bottoming out my rear suspension constantly... tapping the axle into the bumpstops. I didn't feel the need for extra ride height for mall crawling that I do, so I put on a set of superbumps.
In the OP's case, the extra ride height would be great, a resevoir shock that can take the heat generated from constant cycling, and a set of superbumps for the occasion where the axle needs a big deflection upwards (and gets gently slowed by the superbumps, not rammed into the stock rubbers)... should dramatically improve performance.
Assuming that the bushings aren't shot and the arms are the biggest issue anyway.
Keros is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 07:47 AM #9
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
If you’re on your original springs, I would start there. Could be a relatively easy & inexpensive fix.
Bluesky 07 is offline   Reply With QuoteReply With Quote
beat , front , i’m , rear , thinking
Caution!!! Avoid energy suspension - terrible quality! :( 2KT4R 3rd gen T4Rs 17 08-30-2015 10:20 PM
which suspension brand gives the softest ride? runner_mgl Engines / Suspension / Wheels / Tires / Audio / Accessories 6 03-10-2015 02:31 PM
SR5 suspension mod to ride like TE KDSS? Pastanoose 5th gen T4Rs 3 06-28-2014 02:31 PM
Suspension - Most Confortable Ride Dougtoms01 4th Gen T4Rs 8 10-24-2011 04:13 PM
Budget suspension for better ride? collin 3rd gen T4Rs 14 02-22-2010 11:21 PM
