Old 02-05-2020, 08:40 PM #1
4runherpow 4runherpow is offline
4runherpow is on a distinguished road
Knocking sound engine.. need help
Hey Guys,
So I started hearing the hissing type rattle under acceleration only. Sounds like if you put bbs in a tin can and shook the can real fast. Only with throttle. Goes away with foot off gas. Happens driving and neutral but less in neutral.
I popped under the car and gave it some gas with a long lever to see if I could pinpoint the area. Kind of looks like it’s coming from either where the trans meets the engine or somewhere around the engine oil pan. Can’t tell.
But what was even more concerning is when I was revving the engine up to hear the noise, when the engine would slow down from like 2.5k to idle quickly, I’d hear a pretty audible “knock knock thud” coming from what sounds like directly under the engine.
I was able to repeat the noise several times. Didn’t do it every time but probably 2 out 3 times on average.
I’ve done a ton of maintenance recently so hard to pinpoint. But I did do a full trans fluid transfer using the pump method with Valvoline max life, 150 miles ago. I checked the fluid level after using the “warm hand” procedure. Pretty sure the fluid level is correct.
The knocking scares the heck out of me and I have to drive to Vermont tomorrow (500 miles).
Any thoughts are welcome.
4runherpow is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 09:06 PM #2
rumfoord's Avatar
rumfoord rumfoord is offline
rumfoord is on a distinguished road
rumfoord's Avatar
Is the check engine light on? If so get codes read. Had something similar and turned out to be a failing OCV (timing solenoid). Had it replaced and issue never came back. Code should tell you which bank, this which solenoid needs to be replaced.
Originally Posted by 4runherpow View Post
Hey Guys,
rumfoord is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 10:49 PM #3
Thanks for the quick reply.
Was there a knocking noise that prompted you to look further into it or just the code? I don’t have a code right now. Last one was a P0420 code but replaced an o2 sensor a few days ago.
The knocking freaks me out. I’ve put about $6k into her after I bought the rig 3 months ago. She’s finally looking good. Can’t have an engine fail on me
Old 02-05-2020, 10:50 PM #4
What’s the sound of like a failing rod, etc? Never had an issue with that. Someone please talk me down off the ledge!!
Old 02-06-2020, 12:06 AM #5
rumfoord's Avatar
rumfoord's Avatar
Was on a road trip with family and stopped for lunch, when got back in truck started it up felt a little rough. Pulled out of parking lot and could tell the power wasn't there and seemed to sputter, then stopped at a set of lights and engine light came on and could tell timing was off.
We continued to the beach we were heading to and when I pulled up to the gate it started to knock horribly, very scary sound.
When we left I chance it and seemed to drive better at speed, so on Highway was fine. The next day seemed ok, but timing would go off every so often. So had the code checked and mechanic pulled the suspect OCV, tested it and couldn't get it to fail. Cleaned it and put it back in and was fine for a couple days then came back with a vengeance, worse knock than before.
Had the timing chain checked for possibly stretching and was fine, replaced the OCV and all is well.
I feel for ya man, after a year of owning mine I had to replace the head gasket, was not happy about the expense but decided to commit to the vehicle. Been 6 years now and still happy with it, that was the only large expense I had but I won't lie, had plenty of other's that up to roughly 10 grand in total. Bought it believing the Toyota reliability hype but quickly realized that old is old no matter what make and shit will go wrong and I've just accepted that. Still cheaper than buying new.
Good luck man.
Old 02-06-2020, 01:26 AM #6
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Heard a noise like that years ago on a friend's vehicle...bolts between the flex plate and torque converter were loose.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 09:16 AM #7
Good luck man.
I appreciate the detailed story! Wow that was a lot of investigating but sounds like a positive outcome.
Do you have the v6 or v8 out of curiosity?
No check engine code yet. Maybe time to take her in... ughh
Old 02-06-2020, 09:17 AM #8
I read something about the flex plate somewhere.
How is this diagnosed? And how did your buddy figure out that’s what it was?
Thanks
Old 02-06-2020, 10:19 AM #9
Something I noticed too..
It only happens when I rev up quickly and let off the gas quickly.
Also have only been able to recreate the sound while in park or neutral. Do these engines knock when spinning down quickly? Any techs out there??
Old 02-06-2020, 02:42 PM #10
hutchison hutchison is offline
hutchison is on a distinguished road
i would take it to somewhere with a rlift, get it up, and get a stethoscope on it see if you cant pinpoint the noise more.
hutchison is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 06:14 PM #11
ZLJUANN ZLJUANN is offline
ZLJUANN will become famous soon enough
subscribing out of curiosity.
ZLJUANN is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 06:53 PM #12
rumfoord's Avatar
rumfoord's Avatar
It's a V6.
So the knocking is happening often for you? If so probably best to have looked at. If it's the OCV not too expensive and could actually replace yourself, didn't look too difficult.
Old 02-07-2020, 01:46 AM #13
Thanks
He had the car up on ramps and jack stands and ran it in gear (very dangerous and not recommended of course) so he could locate the noise more precisely - which you've already done. Then he removed the access panel and found the flex plate bolts loose....tightened them all to specification and the noise was gone.
Between outfits.
Old 02-11-2020, 03:35 PM #14
Hey Guys,
any updates on this? I have an 06 v8 4wd with only 160k mile with an intermittent knocking sound. I dismissed it as rod knock but there is no metallic particulate in the oil. curious if anything is related here before I pull the engine.
engine , fluid , gas , neutral , trans
Should I be worried (knocking sound). Lindenwood 3rd gen T4Rs 4 04-26-2017 05:58 PM
Knocking sound from engine comparent Cumby 4th Gen T4Rs 6 03-02-2015 02:19 PM
91' v6 3.0, Engine Runs, but Loud RPM-Dependent Knocking Sound Jalon Classic T4Rs 5 01-05-2011 09:22 AM
HELP!!! Knocking Sound Roadhouse_1 4th Gen T4Rs 2 11-02-2008 04:41 PM
