Old 02-08-2020, 06:27 PM #16
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by catrains View Post
coolants are variable on model years .. all have to look up the correct fluids..
THis is not the 1960's..
mixing the antifreeze with different chemicals in other antifreeze will cause problems..
I did the look up for my runner what coolant to use, have to use toyota antifreeze.
you have to use the correct fluids in your model year vehicle.. he commented on saying use fluids on the cheap ..
I do not dump my vehicles in 4 years then buy new. I keep my vehicles probably longer than his age LOL....
just throw anything in your ride on the cheap then buy a new ride next year..
If you read what he posted, he stated to use the CORRECT fluids. Zerex Asian is the CORRECT fluid for the vehicle. I use it in my 2003 4R V8 and I use it in my 1999 Tacoma with the 3.4L. It is correct for BOTH vehicles. Same with oil. I use Shell Rotella T6 in both vehicles and they are running perfectly. The Tacoma has almost 330k miles and the 4R has 282k miles.
You can safely use cheaper equivalents to what the factory recommends, you aren't going to destroy the engine. Don't be like that other guy and the tires....
xtremewlr is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 06:45 PM #17
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I agree that the Zerex Asian is a perfect replacement for the Toyota Long Life coolant, if you read the ingredients they are the same, the Zerex is not a cheap fluid, the Zerezx is normally price whereas the Toyota fluid is marked way up as is all car manufacturer brands are, just because the Zerex costs less doesn't make it an inferior product.
Oil is the same as the coolant marked up from other quality brands.
The one item in this discussion I do agree using the Toyota brand for is the filter, it's surprisingly less expensive than any other filter and is of higher quality from all the test results I have seen than most if not all the others out there.
2004 Limited V8
Old 02-08-2020, 07:03 PM #18
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
you have old Toyota vehicles in a hot climate.. summer temps 110-120F.. rotella T6 40w oil should work in the hot desert..
in my area not gonna work up in the cold northeast .. I switched to the Toyota 0-20wt SN PLUS and it works perfectly than the mobil synthetic 0-20wt .. engine very quiet and a couple of MPG gain..
I use rotella T5 15-40wt in my 1978 mercrusier inboard boat engine .. has flat tappets .. works like new very quiet.. I cannot use new oils made today have to use diesel engine oil .. has more additives to prevent wear ,noise, and corrosion ..
using the wrong coolant in a vehicle can cause internal damage , metals used today vehicles is a problem or mixing different chemicals can cause coolant failures..
some have changed to a different coolant .. they flushed out the system, used an acid cleaner to remove all old coolant.
toyota coolant lasts 10 yrs 120K miles ..made specifically for my 2016 runner.
when you buy a new vehicle write down the manufacturer spec # for the proper fluid it is tricky..then check out if Zerex product has the spec# on your new vehicle then it is the correct fluid...
I looked up mobil 1 advanced engine oil and it did not have the toyota spec #.. but it did have the GM spec #
catrains is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 07:28 PM #19
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
My daughter has a 2013 Tacoma and I put the same fluids in that that I do in both my Toyotas. You can be anal as much as you want about what you are running in your vehicles but don't go telling people they are posting the incorrect fluids just because you don't agree with it. @firebirdguy did not post anything about using the incorrect fluids, nor have I. Adjust your fluid for whatever climate you are in, that doesn't make what we have posted incorrect. Stop being a muffdogg.
Old 02-08-2020, 08:26 PM #20
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Omg none of my fluidz are OEM? Is my truck gonna explode gaiz?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 08:45 PM #21
use the proper fluids as your vehicle manufacturer states. look up the spec # on the proper fluid to use.
I am not telling members to use fluids, NOT of the manufacturer spec #,,,.
SOME on the FORUMS will cause vehicles to fail and cost a load of $$$ .because they stated it is a much cheaper fluid .
be careful do the work and be anal on how to properly keep it running.
one vehicle I owned from day one was a 1983 sedan . ran it 380,000 miles 17 yrs then I sold it for $1700. no major work just brakes/tires/one water pump..that was it !
Old 02-08-2020, 08:48 PM #22
kfs-4runner kfs-4runner is offline
kfs-4runner is on a distinguished road
Originally Posted by 2016 4Runner SR5 View Post
200K is not even close to very high for a 4.0 Report back when you hit 500K Anyway, my personal preference in Toyota synthetic oil and filter and I change it every 5K miles. Since you do so much highway, 8K will likely be fine. I wouldn't push more than that though.
Mobil makes the oil for Toyota I believe so unless Mobil puts in radically different additives for Toyota which they probably do not, you could go with Mobil 1 Synthetic. Just change your oil regularly and use a quality oil filter. I have to believe Mobil 1 would be cheaper than Toyota branded oil. Costco has it for $28 a case right now and Walmart sells it for 25.47 a 5 Qt Jug. If you go to an Oil Change place Mobil 1 will probably be expensive.
kfs-4runner is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 09:09 PM #23
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Yes Mobil does make Toyota oil and yes they do put an insane additive package in it unlike any other oil on the market. The package in Toyota oil is literally 10+ times what you get from the off the shelf version. The Moly content is through the roof which is why the engines run so much quieter when using Toyota oil.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 10:21 PM #24
you make a lot of incorrect assumptions... including my age based on an accurate comment i posted.
i never said to use the WRONG fluids on the cheap. if its rated by the manufacturer for use in that vehicle then its ok to use, such as valvoline maxlife trans fluid instead of toyota WS. i simply suggested a brand of coolant & mentioned it was cheaper than overpriced toyota stuff at a dealership.
Old 02-09-2020, 12:33 PM #25
stop being a muffdogg.
lol!!
Old 02-09-2020, 01:40 PM #26
4Runner4Runner4's Avatar
4Runner4Runner4 4Runner4Runner4 is offline
4Runner4Runner4 is on a distinguished road
What's the model number? I have seen some discussion of a tall filter and a short filter. Any thoughts on using one vs. the other?
2007 4.0L 2Runner SR5
250,000 miles, and adding 4000 more per month!
4Runner4Runner4 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 01:42 PM #27
I SWITCHED TO TOYOTA engine oil SN PLUS from mobil 1. toyota oil works better engine is quiet .. also a increase in MPG.
I do oil changes 7K miles of use but I do not use the runner on hywy use too much .. also I only run it 7K miles a year. 2016 model SR5.
I do the oil changes and I give it 45min for oil to drain.. no debris in the oil filter.. very hard to read the stick of oil level ,very clear oil .no oil drop on the 7K oil changes.
zomg! our 4TH GEN 4Runners aren't spec'd for the new 0w-20 weight moly magic oil! Be careful gaiz!
Old 02-09-2020, 01:51 PM #28
The OEM filter is fine...I use the higher capacity (slightly longer), longer drain interval Fram XG3600. Upside too is that the Fram Ultra is 99% efficient at 20-microns - whereas I believe the OEM one is 50% efficient at 20-microns. Someone over on BITOG even cut apart a Fram Ultra and a TRD (made by Champion) filter to compare.
Old 02-09-2020, 02:15 PM #29
Real Name: Skip
Real Name: Skip
i have only used the short filter, the part number is 90915-YZZD3 , it fits both the V8 and the V6.
2004 Limited V8
Old 02-09-2020, 03:30 PM #30
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
That's actually the long filter, unless there is a longer one than that. The spec'd one for my 3.4L Tacoma uses the shorter version of the YZZD3. I just use the YZZD3 on both motors to keep it simple.
change , full-synthetic , miles , month , oil
It's cheaper for me to buy a no mile / low mile set of take offs Ryan1975 5th gen T4Rs 7 08-03-2017 01:53 PM
Mile high 4runner build thread mile high 4runner 3rd gen T4Rs 19 06-11-2013 07:41 AM
MPG @ sea level vs mile high? Dkon82 4th Gen T4Rs 19 09-22-2011 12:58 PM
100 octane in a high mile regular car Mr.yoshimura Off Topic 7 03-05-2006 11:20 AM
